Adding a standard library to a DSL [message #1858957] |
Wed, 03 May 2023 06:17  |
Written in my DSL, I have a couple of files (`basictypes.rosetta` and `annotations.rosetta`) that can be considered a "standard library" of my DSL, i.e., they should be auto-included in every project and auto-imported in every file.
The auto-importing is easy - I can override the `getImplicitImports` in my scope provider.
It's the auto-inclusion I'm having trouble with. Is there an example I can rely on? I've already tried the following two approaches:
Approach 1: Override `XtextResourceSet` and `SynchronizedXtextResourceSet` and add the standard library there.
E.g.,
public class RosettaResourceSet extends XtextResourceSet {
@Inject
public RosettaResourceSet(RosettaBuiltinsService builtinsService) {
getResources().add(builtinsService.getBasicTypesResource());
getResources().add(builtinsService.getAnnotationsResource());
(similar for `SynchronizedXtextResourceSet`)
In the runtime module:
override Class<? extends ResourceSet> bindResourceSet() {
RosettaResourceSet
override Class<? extends XtextResourceSet> bindXtextResourceSet() {
SynchronizedRosettaResourceSet
This results in a Guice error, and I'm not sure why.
com.google.inject.ProvisionException: Unable to provision, see the following errors:
1) [Guice/CanNotProxyClass]: Tried proxying XtextResourceSet to support a circular dependency, but it is not an interface.
while locating SynchronizedRosettaResourceSet
while locating XtextResourceSet
at TerminalsGrammarAccess.<init>(TerminalsGrammarAccess.java:36)
at TerminalsGrammarAccess.class(TerminalsGrammarAccess.java:36)
at RosettaGrammarAccess.<init>(RosettaGrammarAccess.java:9045)
\_ for 2nd parameter
at RosettaGrammarAccess.class(RosettaGrammarAccess.java:9045)
while locating RosettaGrammarAccess
at LazyLinker.grammarAccess(LazyLinker.java:300)
\_ for field grammarAccess
while locating LazyLinker
at XtextResource.linker(XtextResource.java:474)
\_ for field linker
while locating DerivedStateAwareResource
at SynchronizedRosettaResourceSet.<init>(SynchronizedRosettaResourceSet.java:11)
Approach 2: Override `ResourceSetBasedResourceDescriptions` and `ResourceSetBasedAllContainersStateProvider` and add the standard library there.
E.g.,
public class RosettaResourceDescriptions extends ResourceSetBasedResourceDescriptions {
private final Map<URI, IResourceDescription> standardLibrary;
@Inject
public RosettaResourceDescriptions(
RosettaBuiltinsService builtinsService,
IResourceDescription.Manager manager) {
this.standardLibrary = Map.of(
builtinsService.basicTypesURI, manager.getResourceDescription(builtinsService.getBasicTypesResource()),
builtinsService.annotationsURI, manager.getResourceDescription(builtinsService.getAnnotationsResource())
public Iterable<IResourceDescription> getAllResourceDescriptions() {
return Iterables.concat(
super.getAllResourceDescriptions(),
standardLibrary.values());
public boolean isEmpty() {
return false;
public IResourceDescription getResourceDescription(URI uri) {
IResourceDescription descr = super.getResourceDescription(uri);
if (descr != null) {
return descr;
return standardLibrary.get(uri);
This works fine up to the point where `EcoreUtil.resolve` is called, which expects the referenced EObjects to be in the same resource set as the proxy. In this case however, the resources of the standard library don't belong to a resource set at all.
[Updated on: Wed, 03 May 2023 08:11] by Moderator
Re: Adding a standard library to a DSL [message #1859004 is a reply to message #1858991] |
Fri, 05 May 2023 03:37   |
@Christian
Quote:if you want to continue with the resourcesets:
- why do you have two impls/bindings?
The `DefaultRuntimeModule` provides two bindings, i.e.,
public Class<? extends ResourceSet> bindResourceSet() {
return XtextResourceSet.class;
public Class<? extends XtextResourceSet> bindXtextResourceSet() {
return SynchronizedXtextResourceSet.class;
To be on the safe side, I overrode both. I don't want my solution to fail depending on the way a resource set is injected.
Quote:- you also need to bind it for the builder as this one has its own global resourceset.
I'm not sure I understand what you mean with "the builder".
Quote:maybe you also just want to look into resourcesetinitializers instead of the resourcesets directly
This seems promising. Following this path, I noticed that `XtextGeneratorLanguage` exposes a field called `referencedResources`, which, if I'm not mistaken, are automatically added to resource sets. Would this be a good place to specify my standard lib resources?
I want to make sure that it is actually made available everywhere - that means in all resource sets including the ones created in unit tests and in Xtext's language server.
@Lorenzo
Quote:For ParseHelper, it's enough to make everything available in the same resource set.
Our current approach was to add it manually everywhere. That means we had to create a wrapper for parsing in unit tests, we had to override the AbstractLanguageServerTest, and we need to copy the files whenever we create a new project. That's the dirty current situation I want to get rid of. I guess this isn't the only possible solution, but I thought it would be an elegant one. Apparently there aren't many Xtext DSL's out there which followed the same thought process. :')
Quote:In general, it should also work by properly configuring a resource set. the error you get from Guice maybe means you're doing something wrong with the binding leading to a cycle.
I'm a bit confused. I tried debugging this, so I discarded all dependencies of my `SynchronizedRosettaResourceSet`, but even then the error remains. It only stops when I don't create `XtextResource`s in the constructor, which made me think that a `XtextResource` somehow depends on `XtextResourceSet`, but that doesn't make sense.
General update: I've tried following the route with ResourceDescriptions and Containers, and I actually got it working up to the point where indexes got involved - which is used in Xtext's language server.
Having gone down this road, I'm somehow more confused. It seems that the concept of containers in Xtext is an elegant way of describing dependencies, but the default implementation completely ignores it, and instead uses a "singleton" container called "all" (see `FlatResourceSetBasedAllContainersState.HANDLE`). Having implemented a generalization of this behaviour to define dependencies between resource sets, it's just a shame that this doesn't work when using an index.
It seems the Xtext language server also uses a concept of 'dependencies' (see `org.eclipse.xtext.resource.impl.ProjectDescription::getDependencies`), and briefly having gone through the code, these dependencies seem to be added to the index automatically. I'm not sure whether this is another potential route to follow, or that this will only bring along another rabbit hole. I suspect that I won't be able to generalize this enough to be used in a context outside the Xtext language server as well (e.g., in unit tests), so it's probably not worth following.
Anyway, thanks for the advice, and I look forward to hearing your opinion on the above.
[Updated on: Fri, 05 May 2023 03:40] by Moderator
Re: Adding a standard library to a DSL [message #1859032 is a reply to message #1859008] |
Mon, 08 May 2023 03:44  |
The usecases I want to support is standalone (e.g., for code generation using the Xtext Maven plugin) and LSP (e.g., for running our DSL is VS code) - and internally for unit testing.
The particular case of the Xtext Maven plugin seems to work out-of-the-box, because it automatically scans the classpath for .rosetta files (and our standard lib is included in the classpath). Other "standalone" usecases such as custom scripts for analyzing Rosetta projects currently need to include it manually.
Ideally, I would like to find some common ground which allows me to define a standard library in a single place. What I would like to avoid is having to add support for all of these use cases separately.
FUDForum. Page generated in 1.12649 seconds
