Home » Eclipse Projects » Oomph » Oomph (eclipse-installer) not saving recent dialog preferences
Oomph (eclipse-installer) not saving recent dialog preferences [message #1858888] Fri, 28 April 2023 09:56 Go to next message
For some reason recent session usage of Oomph installer dialog pages are not saved to e.g. <eclipse-installer root>/configuration/.metadata/.plugins/org.eclipse.oomph.setup.ui/dialog_settings.xml.
I am using the installer in the "Advanced mode".
For example, if I check the "Show all variables" check box on the variable page, this setting does not get saved. Next time when I run the eclipse-installer again I have to check this check box again.
At some time in the past (maybe in 2020 / 2021) this behavior was different - each time I did change some config on a dialog page, then this did have been persisted and I did get this as the default dialog setting on subsequent sessions.
I am using the standalone installation of the eclipse.installer unzipped from https://www.eclipse.org/downloads/download.php?file=/oomph/drops/release/1.28.0/products/eclipse-inst-jre-win64.zip and running eclipse-inst.exe.
What would be the pre-requisites to get this working again?
Re: Oomph (eclipse-installer) not saving recent dialog preferences [message #1858893 is a reply to message #1858888] Fri, 28 April 2023 14:08 Go to previous messageGo to next message
Please open a Bugzilla so I don't forget to investigate it.
Re: Oomph (eclipse-installer) not saving recent dialog preferences [message #1858896 is a reply to message #1858893] Fri, 28 April 2023 19:10 Go to previous message
Many thanks for your quick reply!
Bug is filed: https://bugs.eclipse.org/bugs/show_bug.cgi?id=581876
Previous Topic:Packaging plugin within Eclipse IDE installer
Next Topic:Project move: Gerrit -> Gitlab
Current Time: Tue Jun 03 01:01:38 EDT 2025
Powered by FUDForum. Page generated in 0.04857 seconds
