Eclipse Installer Error [message #1858552] |
Thu, 06 April 2023 19:17  |
I'm trying to install Eclipse on my work computer. I downloaded the Eclipse Installer app for macOS Intel x64. When I run it I am presented with a window listing the different Eclipse configurations that can be installed. I selected the "Eclipse IDE for Java Developers" configuration. I then use the defaults for Java 17+ VM location which is "/Users/a07290a/Applications/eclipse/java-2023-03".
I then selected the following as my Installation Folder: /Users/a07290a/Applications/eclipse/java-2023-03. After that I click the INSTALL button and the installation starts but the promptly fails. When I click to see the log I see the following errors:
[2023-04-06 18:25:37] Executing bootstrap tasks
[2023-04-06 18:25:37] OpenJDK Runtime Environment 17.0.6+10
[2023-04-06 18:25:37] Product org.eclipse.products.epp.package.java.2023-03
[2023-04-06 18:25:37] Bundle org.eclipse.oomph.setup 1.26.0.v20230203-1538, build=5840, branch=232d5d6b465d15aa8cd333d7222eabc545dd1478
[2023-04-06 18:25:37] Bundle org.eclipse.oomph.setup.core 1.26.0.v20230204-0932, build=5840, branch=232d5d6b465d15aa8cd333d7222eabc545dd1478
[2023-04-06 18:25:37] Bundle org.eclipse.oomph.setup.p2 1.19.0.v20220607-1104, build=5840, branch=232d5d6b465d15aa8cd333d7222eabc545dd1478
[2023-04-06 18:25:37] Performing P2 Director (Eclipse IDE for Java Developers (2023-03))
[2023-04-06 18:25:37] Offline = false
[2023-04-06 18:25:37] Mirrors = true
[2023-04-06 18:25:37] Resolving 18 requirements from 3 repositories to /Users/a07290a/Applications/eclipse/java-2023-03/Eclipse.app/Contents/Eclipse
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:epp.package.java [4.27.0,5.0.0) (filter=(|(&(osgi.arch=aarch64)(osgi.os=linux)(osgi.ws=gtk))(&(osgi.arch=aarch64)(osgi.os=macosx)(osgi.ws=cocoa))(&(osgi.arch=x86_64)(osgi.os=linux)(osgi.ws=gtk))(&(osgi.arch=x86_64)(osgi.os=macosx)(osgi.ws=cocoa))(&(osgi.arch=x86_64)(osgi.os=win32)(osgi.ws=win32))))
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.platform.feature.group [4.27.0,5.0.0)
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.rcp.feature.group [4.27.0,5.0.0)
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.buildship.feature.group
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.eclemma.feature.feature.group
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.egit.feature.group
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.epp.mpc.feature.group
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.jdt.bcoview.feature.feature.group
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.jdt.feature.group
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.jgit.feature.group
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.m2e.feature.feature.group
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.m2e.lemminx.feature.feature.group
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.m2e.logback.feature.feature.group
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.mylyn.wikitext_feature.feature.group
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.tips.feature.feature.group
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.tm.terminal.feature.feature.group
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.wildwebdeveloper.xml.feature.feature.group
[2023-04-06 18:25:37] Requirement org.eclipse.equinox.p2.iu:org.eclipse.oomph.setup.feature.group
[2023-04-06 18:25:37] Repository https://download.eclipse.org/technology/epp/packages/2023-03/202303091200
[2023-04-06 18:25:37] Repository https://download.eclipse.org/releases/2023-03/202303151000
[2023-04-06 18:25:37] Repository https://download.eclipse.org/oomph/updates/milestone/latest
[2023-04-06 18:25:39] ERROR: org.eclipse.equinox.p2.transport.ecf code=1002 Unable to read repository at https://download.eclipse.org/technology/epp/packages/2023-03/202303091200/content.xml.
javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source)
at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source)
at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.checkServerCerts(Unknown Source)
at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.onConsumeCertificate(Unknown Source)
at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.consume(Unknown Source)
at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source)
at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source)
at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source)
at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)
at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273)
at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241)
at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148)
at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396)
at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158)
at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168)
at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136)
at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51)
at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57)
at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175)
at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96)
at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133)
at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115)
at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170)
at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75)
at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:251)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:71)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source)
at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source)
at java.base/sun.security.validator.Validator.validate(Unknown Source)
at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source)
at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source)
... 1 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source)
at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source)
at java.base/java.security.cert.CertPathBuilder.build(Unknown Source)
... 2 more
FUDForum. Page generated in 0.03796 seconds
