Eclipse for Scientific Computing 2022-23 doesn't support SDM [message #1851080] |
Sun, 27 March 2022 10:01  |
The latest version of Eclipse for Scientific Computing claims to have an 'in-built' parallel debugger-SDM but to me it seems that there is none or it is no more supported, which is quite unfortunate.
Infact I'm able to create and run a parallel C++ application by going to the "run configuration" . However when I do the same with "debug comfiguration", I get an error saying: "/usr/local/bin/sdm" not found.
Although it is clear that in the latest version of eclipse it should not look for this path because as per the latest update the SDM parallel debugger is already installed within. Interestingly, if I go to the "software update" in "HELP" tab, I can see that the SDM is already installed but even then eclipse looks for this path: "/usr/local/bin/sdm".
Any help will be tremendously appreciated.
FUDForum. Page generated in 0.09129 seconds
