Home » Eclipse Projects » Remote Application Platform (RAP) » Clipboard issue in RAP environment
Clipboard issue in RAP environment [message #1857748] Thu, 23 February 2023 18:43 Go to next message
We are implementing a feature that copies text data to the clipboard using the setContents() method of the org.eclipse.swt.dnd.Clipboard class.
When connecting from a localhost PC, it works normally, but when connecting from a remote PC, the following error occurs and it does not work normally.
I want to know the reason.
org.eclipse.swt.SWTError: Cannot set data in clipboard
at org.eclipse.swt.dnd.DND.error(DND.java:263)
at org.eclipse.swt.dnd.DND.error(DND.java:219)
at org.eclipse.swt.dnd.Clipboard.setContents(Clipboard.java:272)
at kr.dazzle.ui.common.EnClipboard.setContents(EnClipboard.java:138)
at kr.dazzle.ui.common.EnClipboard.setContents(EnClipboard.java:124)
at kr.dazzle.ui.tree.actions.CopyCellAction$1.run(CopyCellAction.java:51)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:66)
at kr.dazzle.ui.tree.actions.CopyCellAction.run(CopyCellAction.java:46)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:493)
Re: Clipboard issue in RAP environment [message #1857766 is a reply to message #1857748] Fri, 24 February 2023 05:34 Go to previous messageGo to next message
Which browser are you using - Chrome or Firefox?
There is a difference between the too.
Ivan
Re: Clipboard issue in RAP environment [message #1857767 is a reply to message #1857748] Fri, 24 February 2023 05:37 Go to previous messageGo to next message
... on first run there should be a browser native dialog pops up that asks for permission to access the clipboard.
Re: Clipboard issue in RAP environment [message #1857930 is a reply to message #1857766] Tue, 07 March 2023 03:42 Go to previous messageGo to next message
This symptom occurs in both chrome and firefox.
And no error popup is displayed in the browser.
I also checked if Javascript errors were output using developer tools, but no errors were output.
Thank you for your reply and interest. ^^
[Updated on: Tue, 07 March 2023 03:51] by Moderator
Re: Clipboard issue in RAP environment [message #1857940 is a reply to message #1857930] Tue, 07 March 2023 09:14 Go to previous messageGo to next message
show us code pls
I have tried all ways and there are not problems with clipboard (chrome safari firefox)
Re: Clipboard issue in RAP environment [message #1857947 is a reply to message #1857940] Tue, 07 March 2023 19:58 Go to previous messageGo to next message
I wrote a sample program to reproduce this problem.
The mail template plugin of the RAP sample has been slightly modified and works as follows.
index.php/fa/43002/0/
This is a simple sample that saves the entered sentence to the clipboard when you enter a sentence in the text field and click the "Copy" button.
If you test with the URL below on the device where the server is running, it works perfectly.
http://localhost:Port/mail
but,
If you test by accessing the URL below from another device, an error occurs.
http://IP:Port/mail
Am I just not sure how to use it properly?
I hope so. ^^
Here's the code that implements clipboard handling:
public class ViewComposite extends Composite {
	private Text text;
	 * Create the composite.
	 * @param parent
	 * @param style
	public ViewComposite(Composite parent, int style) {
		super(parent, style);
		setLayout(new GridLayout(3, false));
		Label lblText = new Label(this, SWT.NONE);
		lblText.setLayoutData(new GridData(SWT.RIGHT, SWT.CENTER, false, false, 1, 1));
		lblText.setText("Text: ");
		text = new Text(this, SWT.BORDER);
		text.setLayoutData(new GridData(SWT.FILL, SWT.CENTER, true, false, 1, 1));
		Button btnCopy = new Button(this, SWT.NONE);
		btnCopy.addSelectionListener(new SelectionAdapter() {
			public void widgetSelected(SelectionEvent e) {
				String str = text.getText();
				System.out.println("Text:" + str);
				Clipboard clipboard = new Clipboard(getDisplay());
				clipboard.setContents(new Object[] { str }, new Transfer[] { TextTransfer.getInstance() });
		btnCopy.setText("Copy");
	protected void checkSubclass() {
		// Disable the check that prevents subclassing of SWT components
  • Attachment: ClipboardTest.zip
    (Size: 30.81KB, Downloaded 105 times)
  • Attachment: OK.png
    (Size: 26.79KB, Downloaded 371 times)
[Updated on: Tue, 07 March 2023 20:03] by Moderator
Re: Clipboard issue in RAP environment [message #1857970 is a reply to message #1857947] Wed, 08 March 2023 17:32 Go to previous messageGo to next message
I'm not sure
but try to replace getDisplay(). to Display.getCurrent()
and add clipboard.dispose() after setContents
Re: Clipboard issue in RAP environment [message #1857975 is a reply to message #1857970] Thu, 09 March 2023 01:13 Go to previous messageGo to next message
Unfortunately, even though I corrected it as instructed, the problem remains.
				Clipboard clipboard = new Clipboard(Display.getCurrent());
				clipboard.dispose();
Re: Clipboard issue in RAP environment [message #1858004 is a reply to message #1857975] Fri, 10 March 2023 09:18 Go to previous messageGo to next message
magic.. lets try to isolate the problem
try copy to clipboard from my RAP application. (code is the same)
https://159.69.216.78:5020/start
=>enter
=> select any table =>mouse menu=> Copy rows=> click on copy button
If you will still have the problem that possible there is browser problem
Re: Clipboard issue in RAP environment [message #1858013 is a reply to message #1858004] Fri, 10 March 2023 20:48 Go to previous messageGo to next message
oh!!!
I did it the way you told me to, and it worked fine.
I found a difference between my environment and yours.
I tested with HTTP and your environment is HTTPS.
I found the exact cause, and confirmed that my application works perfectly when connected to HTTPS.
When accessing via HTTP, for security reasons, only localhost was allowed and the rest were blocked.
thank you.
And TSMExplorer is awesome!!
I am also working on a site using RAP. Please stop by when you have time.
https://www.dazzleat.link/
Re: Clipboard issue in RAP environment [message #1858078 is a reply to message #1858013] Tue, 14 March 2023 18:18 Go to previous message
good news
clipboard works well
Previous Topic:Focus issues with ContextMenu in Chrome browser
Next Topic:Is RAP still heavily in use - or are there other stacks recommended?
Current Time: Tue Sep 23 05:31:00 EDT 2025
Powered by FUDForum. Page generated in 0.05873 seconds
