Home » Eclipse Projects » Eclipse Titan » Assignment of ASN.1 based template
Assignment of ASN.1 based template [message #1857566] Wed, 15 February 2023 08:48 Go to next message
Hi TTCN / ASN.1 experts,
we found an issue which may be a bug in the Titan compiler, as follows:
In the project attached in file Test.ttcn: 54 we have an assignment
 v_tmpB := v_tmpA;
v_tmpA and v_tmpB are of different types but the types have identical structures, and according to the TTCN language spec clause 6.3.2 the assignment should be valid, but we get a runtime error:
Dynamic test case error: Values or templates of types `@SDAP-CONFIG-ASN1-Definitions.SetupRelease.SDAP-CONFIG-ASN1-Definitions.inst3' and `@SDAP-CONFIG-ASN1-Definitions.SetupRelease.SDAP-CONFIG-ASN1-Definitions.inst4' are not compatible at run-time
To make the project just type make, to run ./Test Test.cfg.
Any comments would be appreciated,
Olaf @ ETSI TF160
Re: Assignment of ASN.1 based template [message #1857640 is a reply to message #1857566] Fri, 17 February 2023 11:34 Go to previous messageGo to next message
Hi Olaf,
this issue has been resolved in the current build.
Botond Baranyi
Re: Assignment of ASN.1 based template [message #1857641 is a reply to message #1857640] Fri, 17 February 2023 12:20 Go to previous message
Wow, Botond,
I confirm that the issue has been solved.
I will communicate this to our customers using the 5G 3GPP/ETSI test suite.
Thanks and have nice week end
Previous Topic:Titan 8.3.0 release notification
Next Topic:ASN.1 Information Objects parsing error
Current Time: Mon Jul 21 15:27:30 EDT 2025
Powered by FUDForum. Page generated in 0.05655 seconds
