Home » Newcomers » Newcomers » Cannot install eclipse(Eclipse installer stuck on downloading artifacts)
Cannot install eclipse [message #1843803] Thu, 19 August 2021 03:20 Go to next message
index.php/fa/40864/0/index.php/fa/40862/0/Hi,
I am having an issue where the eclipse installer is stuck on downloading artifacts.
It shows me this message in a yellow box Quote:
Artifact download is progressing very slowly from http://download.eclipse.org
Does anyone know why this is happening? I was previously on the 2020 version of eclipse.
Re: Cannot install eclipse [message #1843821 is a reply to message #1843803] Thu, 19 August 2021 11:05 Go to previous messageGo to next message
This would normally come from a mirror that would be close by to you and be relatively fast. But looking at the script that the framework uses to download artifacts, it seems to say there are currently no mirrors so it will load directly from Eclipse and that's likely to be very slow:
https://www.eclipse.org/downloads/download.php?file=/justj/jres/16/updates/release/16.0.2/plugins/org.eclipse.justj.openjdk.hotspot.jre.full.win32.x86_64_16.0.2.v20210721-1149.jar
Which is strange, because all these sites are mirrors:
https://download.eclipse.org/oomph/archive/mirror.php?location=justj/jres/16/updates/release/16.0.2/plugins
I expect you don't have Java 11 installed on your machine so the installer offers to download a JRE for you. But it's quite big and takes time when download Eclipse directly. I've opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=575511 to report the problem.
Re: Cannot install eclipse [message #1843827 is a reply to message #1843821] Thu, 19 August 2021 13:04 Go to previous messageGo to next message
There is a server in my region yet eclipse downloads from Canada which is not even close to where I am. Wired issue anyway I am running on the 2020-12 version right now. Il try to reinstall it later
Re: Cannot install eclipse [message #1857416 is a reply to message #1843827] Mon, 06 February 2023 08:16 Go to previous messageGo to next message
No Message Body
Re: Cannot install eclipse [message #1857418 is a reply to message #1857416] Mon, 06 February 2023 11:07 Go to previous messageGo to next message
It looks like the installation is in progress, though one of the mirrors being used appears to be slow.
Re: Cannot install eclipse [message #1859080 is a reply to message #1843803] Wed, 10 May 2023 11:53 Go to previous messageGo to next message
As download.eclipse.org is the main site where all the mirrors get their data from, I suggest not using it for end user IDE downloads at all. It is super slow already.
Re: Cannot install eclipse [message #1859082 is a reply to message #1859080] Wed, 10 May 2023 20:51 Go to previous message
Dont use IDE its very slow recently
Previous Topic:Get Eclipse variables Programaticly
Next Topic:Set the Global Arm Toolchain Path Programaticly
Current Time: Thu Nov 06 04:39:21 EST 2025
Powered by FUDForum. Page generated in 0.10057 seconds
