Home » Newcomers » Newcomers » Eclipse with support for BOTH Java and PHP
Eclipse with support for BOTH Java and PHP [message #1857397] Fri, 03 February 2023 18:08 Go to next message
Not sure which forum to post this in, so I'll post it here.
I have been running eclipse for a long time with straight java support. I now wish to add PHP support. I have an older Oxygen, but I have no problem upgrading or replacing.
When I go to eclipse it suggests that I "Select" which I want. If i select java and install then come back and select php, will i have 2 installations of eclipse?
How can I have eclipse supporting both, and I choose what I'm doing when I create a project. Do I download a general version and then start figuring out what plugins to add?
What approach is suggested?
thanks
Re: Eclipse with support for BOTH Java and PHP [message #1857405 is a reply to message #1857397] Sat, 04 February 2023 12:38 Go to previous message
If you mean from inside Eclipse and not the Installer, no, you'll have support for both in the same installation.
Previous Topic:java.lang.NoClassDefFoundError
Next Topic:Unable to deploy JRE .msi in Intune
Current Time: Sun Jul 20 22:38:24 EDT 2025
Powered by FUDForum. Page generated in 0.10027 seconds
