Re: EclipseLogListener Unhandled event loop exception - instance of org/eclipse/osgi/internal/basead [message #1857342 is a reply to message #1857333] |
Wed, 01 February 2023 03:14  |
we are using org.eclipse.equinox.launcher_1.3.0-SDK-4.2.1.jar to launch, felix is using to create the bundles
we have a common system bundle which provides common tasks like logging.
The system bundle is in resolved status and is used across the other bundles
osgi> packages com.test.system.instrument.measurement
com.test.system.instrument.measurement; version="3.4.0"<com.test.system.instrument_3.4.0 [64]>
com.test.common.string_1.4.0 [9] imports
when the bundle is used we are getting
SEVERE: [{ERROR - MISSING RESOURCE}{RESOURCE KEY - com.test.rcp.viewer.utility.EclipseLogListener Unhandled event loop exception}]
Jan 27, 2023 4:22:27 PM com.test.rcp.viewer.utility.EclipseLogListener logging
SEVERE: [{ERROR - MISSING RESOURCE}{RESOURCE KEY - com.test.rcp.viewer.utility.EclipseLogListener }]
java.lang.LinkageError: loader constraint violation: loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) previously initiated loading for a different type with name "com/test/system/instrument/measurement/Measurement"
at com.test.markup.conversion.impl.RtfConverter.convert(RtfConverter.java:172)
at com.test.rcp.core.utility.RTFUtility.getHTMLBytesFromRTFContent_ThrowsException(RTFUtility.java:75)
at com.test.rcp.core.utility.RTFUtility.getHTMLBytesfromRTFFile(RTFUtility.java:107)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at com.test.rcp.viewer.firstnet.view.FirstnetSearchView$11$1.run(FirstnetSearchView.java:626)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at com.test.rcp.viewer.Application.lambda$start$1(Application.java:183)
at com.test.rcp.viewer.Application.start(Application.java:179)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
FUDForum. Page generated in 0.03429 seconds
