Home » Eclipse Projects » EclipseLink » Migration from Eclipselink 3.0.2 to 4.0.0(java.lang.NoClassDefFoundError JsonPlatform)
Migration from Eclipselink 3.0.2 to 4.0.0 [message #1857258] Thu, 26 January 2023 15:31 Go to next message
I updated the EclipseLink libraries from version 3.0.2 to 4.0.0 in a Java project with MySQL.
When trying to connect to the database I get this error:
java.lang.NoClassDefFoundError: org/eclipse/persistence/json/JsonPlatform
What archive jar is this class in? Why can't the compiler find it? Thank you.
Re: Migration from Eclipselink 3.0.2 to 4.0.0 [message #1857268 is a reply to message #1857258] Fri, 27 January 2023 04:25 Go to previous message
org.eclipse.persistence.json.JsonPlatform
is new class introduced by
https://github.com/eclipse-ee4j/eclipselink/pull/1389 into EclipseLink 4.x version.
It's available in following artifact:
org.eclipse.persistence:org.eclipse.persistence.json:4.0.0
https://search.maven.org/artifact/org.eclipse.persistence/org.eclipse.persistence.json/4.0.0/jar
About mentioned error:
I'd like now:
1. Full error stack which leads into this exception
2. Your dependencies. Classpath | Modulepath and list of EclipseLink dependencies
3. Platform class, if specified in the
persistence.xml
file
Previous Topic:Eclipselink 2.6.9 - Select statements in Logs
Next Topic:Find managed entities in PersistenceContext
Current Time: Mon May 12 21:02:18 EDT 2025
Powered by FUDForum. Page generated in 0.03819 seconds
