Home » Newcomers » Newcomers » Java 6.0
Java 6.0 [message #185717] Tue, 26 December 2006 20:22 Go to next message
Originally posted by: william.rouse.ws
Now that java 6.0 is released, are there any adjustments or additions that
need to be made to Eclipse?
WBR
Re: Java 6.0 [message #185725 is a reply to message #185717] Tue, 26 December 2006 21:38 Go to previous messageGo to next message
Originally posted by: wayne.beaton._NOSPAM_eclipse.org
> that need to be made to Eclipse?
> WBR
Nope. Eclipse 3.2 supports Java 6.0. You have to either set the
workspace preferences Java > Compiler to Java 6.0 (to set the workspace
default) or you can set the same preference on individual projects.
It all runs well on Java 6.0. I've been running it for months.
HTH,
Wayne
Re: Java 6.0 [message #185816 is a reply to message #185725] Wed, 27 December 2006 17:16 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Wayne Beaton" <wayne.beaton@_NOSPAM_eclipse.org> wrote in message
news:4591DCB7.5060901@_NOSPAM_eclipse.org...
>> WBR
> Nope. Eclipse 3.2 supports Java 6.0. You have to either set the workspace
> preferences Java > Compiler to Java 6.0 (to set the workspace default) or
Slight amendment: Eclipse 3.2 supports the Java 6 language, but not all the
features of Java 6. For instance, Java 6 (JSR-269) annotation processors
will not run on Eclipse 3.2.
Eclipse 3.3 will add the missing pieces.
Re: Java 6.0 [message #185824 is a reply to message #185816] Wed, 27 December 2006 19:53 Go to previous messageGo to next message
Wayne:
Thanks! I got it to work with just a little sputter.
Walter:
What is "Java 6 (JSR-269) annotation processors"?
Thanks to all;
WBR
Re: Java 6.0 annotation processing [message #185985 is a reply to message #185824] Thu, 28 December 2006 19:26 Go to previous messageGo to next message
"William Bradley Rouse" <william@rouse.ws> wrote in message
news:cae73f4aa3faa78f36f881e4df424bf9$1@www.eclipse.org...
> Wayne:
> Walter:
In Java 5, Sun introduced the concept of "annotation processing" - a way for
third-party code to run at compile time and be able to inspect annotations
on the source code and generate additional Java classes that would then get
compiled along with the original source code. Among other things, it's a
way of formalizing things like EJB generation that had been done with tools
based on javadoc. There are many advantages, such as type-safety (to
javadock, everything is a string).
However, in Java 5, the interface that these "annotation processors" had to
talk to was a Sun proprietary interface, com.sun.mirror.apt.*. In Java 6,
the interface has been standardized (it's in javax.annotation.processing and
javax.lang.model), .
Eclipse 3.2 supported Sun-style Java 5 annotation processors: that is, it is
possible to write annotation processors and it is possible to add them to
the Java build. Eclipse 3.3 will support the new Java 6 standard, along
with the old non-standard interface.
You can read a bit more about them, if you choose to, at
http://www.eclipse.org/jdt/apt/introToAPT.html. Note that still does not
mention Java 6.
Re: Java 6.0 annotation processing [message #186109 is a reply to message #185985] Sat, 30 December 2006 03:47 Go to previous message
Thank you Walter.
WBR
Previous Topic:Update Manager - not finding "new features"
Next Topic:adobe livecycle
Current Time: Sun Aug 17 11:48:27 EDT 2025
Powered by FUDForum. Page generated in 0.08078 seconds
