Home » Eclipse Projects » Oomph » Configuring tools.jar as JRE Library of Java 8 JRE ?
Configuring tools.jar as JRE Library of Java 8 JRE ? [message #1857142] Thu, 19 January 2023 11:33 Go to next message
I would like to know / understand if this is possible to configure a Java JRE to have the (unfamous) tools.jar as JRE library in a installation setup:
    <setupTask
        xsi:type="jdt:JRETask"
        version="JavaSE-1.8"
        location="${jre.location-1.8}">
      <jreLibrary
          libraryPath="../lib/tools.jar"
          externalAnnotationsPath="../lib/tools.jar"/>
    </setupTask>
The task is not adding the tools.jar and I don't know what's wrong here (JDK is added, and I get an error if I don't have externalAnnotationsPath).
Re: Configuring tools.jar as JRE Library of Java 8 JRE ? [message #1857154 is a reply to message #1857142] Fri, 20 January 2023 03:39 Go to previous messageGo to next message
I'll need to investigate, time permitting. Or you can set up an Oomph environment:
https://www.eclipse.org/setups/installer/?url=http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/configurations/OomphConfiguration.setup&show=true
Start the Runtime Workspace, use Navigate -> Open Setup -> Workspace, copy your JRE task in there, run Help -> Perform Setup Tasks, and then debug what happens in JRETaskImpl.perform to help fix any problem either in the code or in what you have specified in the task.
Re: Configuring tools.jar as JRE Library of Java 8 JRE ? [message #1857157 is a reply to message #1857154] Fri, 20 January 2023 04:44 Go to previous messageGo to next message
In debug, yes, I can see the library being processed ... but my understanding of the task :
IPath installPath = new Path(installLocation.getCanonicalPath());
            for (JRELibrary jreLibrary : jreLibraries)
              String libraryPath = jreLibrary.getLibraryPath();
              String externalAnnotationsPathLiteral = jreLibrary.getExternalAnnotationsPath();
              if (libraryPath != null && externalAnnotationsPathLiteral != null)
                IPath jreLibraryPath = installPath.append(libraryPath);
                LibraryLocation[] libraryLocations = vmStandin.getLibraryLocations();
                for (int i = 0; i < libraryLocations.length; i++)
                  LibraryLocation libraryLocation = libraryLocations[i];
                  IPath systemLibraryPath = libraryLocation.getSystemLibraryPath();
                  if (jreLibraryPath.equals(systemLibraryPath))
                    Path externalAnnotationsPath = new Path(externalAnnotationsPathLiteral);
                    try
                      if (!externalAnnotationsPath.equals(libraryLocation.getExternalAnnotationsPath()))
                        LibraryLocation newLibraryLocation = new LibraryLocation(systemLibraryPath, libraryLocation.getSystemLibrarySourcePath(),
                            libraryLocation.getPackageRootPath(), libraryLocation.getJavadocLocation(), libraryLocation.getIndexLocation(),
                            externalAnnotationsPath);
                        libraryLocations[i] = newLibraryLocation; // <-- update existing
                    catch (NoSuchMethodError ex)
                      //$FALL-THROUGH$
                    break;
Is that me or this code is only adding the "external annotation" to the existing library and completely ignoring new JRE libraries ?
I also see in debug that I should use lib/tools.jar because the install path if the JDK home, rather than the JRE home.
I tried to fix that:
          if (!jreLibraries.isEmpty())
            if (vmStandin.getLibraryLocations() == null)
              // We have to set this to an empty array first in order for the real setLibraryLocations() call to have any effect.
              vmStandin.setLibraryLocations(new LibraryLocation[0]);
              vmStandin.setLibraryLocations(type.getDefaultLibraryLocations(installLocation));
            List<LibraryLocation> newLibraryLocations = new ArrayList<>(asList(libraryLocations));
              if (libraryPath != null)
                boolean found = false;
                if (externalAnnotationsPathLiteral != null)
                      try
                          found = true;
                        //$FALL-THROUGH$
                      break;
                if (!found)
                  // (IPath libraryPath, IPath sourcePath, IPath packageRoot, URL javadocLocation, URL indexLocation, IPath externalAnnotations)
                  IPath sourcePath = Path.EMPTY;
                  IPath packageRoot = Path.EMPTY;
                  URL javadocLocation = null;
                  URL indexLocation = null;
                  IPath externalAnnotationsPath = externalAnnotationsPathLiteral == null ? null : new Path(externalAnnotationsPathLiteral);
                  newLibraryLocations
                      .add(new LibraryLocation(jreLibraryPath, sourcePath, packageRoot, javadocLocation, indexLocation, externalAnnotationsPath));
            vmStandin.setLibraryLocations(newLibraryLocations.toArray(LibraryLocation[]::new));
This effectively add the new tools.jar in the libraries, there is a red cross in the Installed JREs system libraries for the one I added.
It seems it is related to the "external annotation" => the setup should ignore it, but I kind of remember that I was forced to set an externalAnnotationsPath attribute.
Re: Configuring tools.jar as JRE Library of Java 8 JRE ? [message #1857177 is a reply to message #1857157] Sat, 21 January 2023 07:51 Go to previous message
It looks to me like this code (which was contributed, not written by me) was only designed to add annotations to and existing library path entry.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=526214
I suppose it could be extended to allow adding additional jars...
Previous Topic:Problem with installing.
Next Topic:Maven Location
Current Time: Tue Sep 16 23:40:29 EDT 2025
Powered by FUDForum. Page generated in 0.03582 seconds
