Home » Modeling » QVT-OML » QVTo transformation with Xtext target models
QVTo transformation with Xtext target models [message #1857003] Thu, 12 January 2023 09:02 Go to next message
I am writing some QVTo transformations for (UML -> Xtext) instances.
The issue I am encountering is that the generated target models are generated as XMI and not serialised as Xtext files. I tried even just one single mapping rule, and the result is still the same (xmi).
Then I tried to erase what was generated in that file and write something conforming to the xtext grammar, and when I try to write something myself it works fine (conforms to the xtext grammar), but when I generate it, it does not. Any idea on what it might be, or at least how I can understand what might be going wrong? Thank you!
Re: QVTo transformation with Xtext target models [message #1857005 is a reply to message #1857003] Thu, 12 January 2023 09:12 Go to previous messageGo to next message
Hi John
Probably a duplicate of this thread: https://www.eclipse.org/forums/index.php?t=rview&goto=1856671
Without a repro, that problem will be hard to solve. Which file extension do you specify for your target models? Do you run the transformation programmatically (Eclipse or standalone) or manually using QVTo's launch configurations?
Kind regards
Christopher
Re: QVTo transformation with Xtext target models [message #1857012 is a reply to message #1857005] Thu, 12 January 2023 15:15 Go to previous messageGo to next message
The Xtext serializer should work automatically when you use the appropriate extension; as you have found.
But the serializer can fail with a fairly verbose and fairly informative exception when the auto-generated model does not comply with a regular generation.
I spent many 'pleasant' hours debugging for OCL and QVTd serialization. I think I eventually agreed that the serializer was correct each time. Debugging can be assisted by saving first to a *.xmi file before the *.xtext. This gives you an XMI file to study wrt the exception.
While you are getting your 'eye in' on the exception message, you may find it helpful to do a side-by-side comparison of the XMI for small examples; forward-Xext versus your programatic-generation. This will enable you to understand the multiplicities in the diagnostics; it is nearly always a multiplicity bug, but sometimes it's ancestry.
Ed Willink
[Updated on: Thu, 12 January 2023 15:27] by Moderator
Re: QVTo transformation with Xtext target models [message #1857038 is a reply to message #1857012] Fri, 13 January 2023 14:40 Go to previous messageGo to next message
Attached to this reply I am sending a repro, with a very simple example where starting from a UML Model which only has a package, by writing QVTo transformations I am trying to convert it to a .myDsl file conforming to an Xtext grammar, in which I have defined Package as a concept.
My work is much bigger, but this happens even with this simple example. In the repro you can find the Xtext files, and a folder named "TestTransformations" which should be imported in the runtime instance. My.uml is the source model and TestTransformation.xmi and TestTransformation.myDsl are the target models that are an output of running the QVTo transformation. I have also included the launch configuration file.
Thanks for any help!
[Updated on: Fri, 13 January 2023 14:47] by Moderator
Re: QVTo transformation with Xtext target models [message #1857040 is a reply to message #1857038] Fri, 13 January 2023 15:15 Go to previous message
Hi John
The file extensions are case-sensitive. Your workflow registers the mydsl extension, while your launch configuration produces a myDsl file. Changing the launch configuration to mydsl, I receive a target file including the string "test".
I assume that you got your setup right, so all the MyDSL projects must be running plugins inside a runtime Eclipse to enable the Xtext support (placing them as projects in your workspace won't be sufficient for serialization).
Kind regards
Christopher
Previous Topic:Transform UML models with applied profile
Next Topic:Output model into separate files
Current Time: Thu Jul 31 03:09:28 EDT 2025
Powered by FUDForum. Page generated in 0.05139 seconds
