Home » Modeling » TMF (Xtext) » exec-maven-plugin with Xtext(SecurityException on org.eclipse.core.runtime.OperationCanceledException)
exec-maven-plugin with Xtext [message #1856950] Tue, 10 January 2023 11:06 Go to next message
Is there a way of configuring `exec-maven-plugin` to work with Xtext/Tycho?
I have a main file `GenerateTmGrammar` that needs grammar access to my DSL, i.e., it needs to run
Injector inj = new MyDSLStandaloneSetup().createInjectorAndDoEMFRegistration();
MyDSLGrammarAccess grammarAccess = inj.getInstance(MyDSLGrammarAccess.class);
Grammar grammar = grammarAccess.getGrammar();
Set<String> keywords = GrammarUtil.getAllKeywords(grammar);
However, when running a `mvn clean install` on the parent project, I'm getting the following error:
An exception occurred while executing the Java class. com.google.common.util.concurrent.UncheckedExecutionException: java.lang.SecurityException: class "org.eclipse.core.runtime.OperationCanceledException"'s signer information does not match signer information of other classes in the same package
Interestingly, I'm not getting this error when I run `mvn clean install` on the actual submodule containing `GenerateTmGrammar.java`.
Before I imported anything related to Xtext the plugin was running fine.
Does anybody have experience with setting this up? Any solutions/workarounds?
`exec-maven-plugin` configuration:
<plugin>
	<groupId>org.codehaus.mojo</groupId>
	<artifactId>exec-maven-plugin</artifactId>
	<version>3.1.0</version>
	<executions>
		<execution>
			<id>Generate TextMate grammar json file</id>
			<phase>prepare-package</phase>
			<goals>
				 <goal>java</goal>
			 </goals>
			<configuration>
				<mainClass>com.example.mydsl.ide.textmate.GenerateTmLanguage</mainClass>
				<arguments>
					<argument>${project.basedir}/mydsl.tmLanguage.yaml</argument>
					<argument>${project.basedir}/src-gen/syntaxes/mydsl.tmLanguage.json</argument>
				</arguments>
				<classpathScope>compile</classpathScope>
			</configuration>
		</execution>
	</executions>
</plugin>
Note that I've added `<classpathScope>compile</classpathScope>`. Before that, it wasn't finding my dependency on SnakeYAML, which I added to the target file of my project. I'm not sure why.
[Updated on: Tue, 10 January 2023 11:32] by Moderator
Re: exec-maven-plugin with Xtext [message #1856951 is a reply to message #1856950] Tue, 10 January 2023 11:12 Go to previous messageGo to next message
have no idea but
this looks like an inconsistent use of ecore.runtime and equinox.common.
by using matching explicit versions for both the problem should vanish
Re: exec-maven-plugin with Xtext [message #1856967 is a reply to message #1856951] Wed, 11 January 2023 03:59 Go to previous messageGo to next message
Thanks! Adding these two dependencies to the plugin actually solved it.
After that, I noticed that I actually had some dependencies defined in Maven that were conflicting with Tycho. Once I replaced all explicit Maven dependencies with the corresponding target platform/Tycho dependencies, I could run exec-maven-plugin without the additional dependencies. So the actual cause was a problem in my Maven configuration.
[Updated on: Wed, 11 January 2023 04:00] by Moderator
Re: exec-maven-plugin with Xtext [message #1856970 is a reply to message #1856967] Wed, 11 January 2023 04:57 Go to previous messageGo to next message
Hm, although now I'm getting a `FileSystemNotFoundException: Provider "bundleresource" not installed` exception while running unit tests. @Christian Dietrich, do you have an idea in which dependency file system support for `bundleresource` is defined?
Tests are fine when I run them in Eclipse.
[Updated on: Wed, 11 January 2023 05:10] by Moderator
Re: exec-maven-plugin with Xtext [message #1856977 is a reply to message #1856970] Wed, 11 January 2023 07:51 Go to previous messageGo to next message
can you try with a clean maven repo -Dmaven.repo.local=somedir
what is the complete stacktrace and what does the code that crashes do?
[Updated on: Wed, 11 January 2023 07:58] by Moderator
Re: exec-maven-plugin with Xtext [message #1856978 is a reply to message #1856970] Wed, 11 January 2023 08:04 Go to previous messageGo to next message
Never mind, I got a workaround. Just opened the resource as a stream instead of opening it as a URL and converting it to a file path.
Thanks for the help!
[Updated on: Wed, 11 January 2023 08:04] by Moderator
Re: exec-maven-plugin with Xtext [message #1856979 is a reply to message #1856978] Wed, 11 January 2023 08:08 Go to previous message
so its about plugin tests, not (pure) unit tests
Previous Topic:Grammar solution request
Next Topic:Formatting: respect newlines
Current Time: Thu Sep 18 09:23:48 EDT 2025
Powered by FUDForum. Page generated in 0.29296 seconds
