Home » Language IDEs » Java Development Tools (JDT) » Syntax Highlighting Problem
Syntax Highlighting Problem [message #1856907] Sun, 08 January 2023 17:35 Go to next message
Settings in [Preferences > Java > Editor > Syntax Coloring] are not saved when Eclipse Dark theme is enabled.
To reproduce:
    Install Platform Runtime Library (eclipse-platform-4.26-win32-x86_64.zip)
    Install Java Development Tools
    Enable Dark theme
    Customize Java Syntax Coloring
    Exit and relaunch Eclipse
    Java Syntax Coloring preferences are now back to default (honestly, an eyesore)
Am i doing something wrong? I basically wasted this evening trying to make the settings stay. Even manually editing workspace\.metadata\.plugins\org.eclipse.core.runtime.settings\org.eclipse.jdt.ui.prefs does not work because of CSS override.
Re: Syntax Highlighting Problem [message #1856910 is a reply to message #1856907] Mon, 09 January 2023 02:22 Go to previous messageGo to next message
Maybe you recorded the preferences settings in the past and they are being re-applied each time you start any workspace? Some details are here:
https://github.com/eclipse-platform/.github/issues/81#issuecomment-1361342695
Of course if it really is the CSS ignoring the preferences that sounds like a bug to me. But even then, you could consider contributing the improvements/fixes for the CSS:
https://github.com/eclipse-platform/.github/blob/main/CONTRIBUTING.md
Re: Syntax Highlighting Problem [message #1856915 is a reply to message #1856910] Mon, 09 January 2023 03:31 Go to previous messageGo to next message
I reinstalled Eclipse multiple times with different versions (2022-12 and 2020-06) with multiple JREs (19.0.1 - 1.8)
I was afraid the workspace directory was left in a dirty state so i deleted the folder everytime before making any new attempt.
Never managed to disable Syntax coloring in Java Editor Preferences.
If you disable Themes in General > Appearance, disabling Syntax coloring works correctly every time.
As an update:
Changes in colors in [Preferences > Java > Editor > Syntax Coloring] work correctly. Changes in Enabled/Disabled state won't stick and are reset when you restart Eclipse when Dark Theme (or themes in general) in enabled
[Updated on: Mon, 09 January 2023 03:33] by Moderator
Re: Syntax Highlighting Problem [message #1856917 is a reply to message #1856915] Mon, 09 January 2023 05:56 Go to previous message
And you have confirmed that this isn't happening because you previously recorded preferences?
Previous Topic:Exported jar files not working
Next Topic:Maps from local machine to display with GeoMap
Current Time: Sat Aug 30 19:58:34 EDT 2025
Powered by FUDForum. Page generated in 0.04401 seconds
