Home » Eclipse Projects » Subversive » Svn Connectors site not available(Installed SVN last night but the connectors site is unavailable)
Svn Connectors site not available [message #1856252] Tue, 29 November 2022 11:35 Go to next message
Window->Preferences->Team->SVN->SVN Connector->Get Connectors.
community.polarion.com
Even ping fails.
Re: Svn Connectors site not available [message #1856256 is a reply to message #1856252] Tue, 29 November 2022 15:05 Go to previous messageGo to next message
Looks like it went offline sometime last week.
http://community.polarion.com/projects/subversive/download/eclipse/6.0/update-site/
In particular we use the JavaHL 1.9 connector.
index.php/fa/42753/0/
The 4.8 install instructions references a new site: https://osspit.org/eclipse/subversive-connectors/ . But it only has the SVNKit 1.10 connector.
index.php/fa/42752/0/
[Updated on: Tue, 29 November 2022 15:05] by Moderator
Re: Svn Connectors site not available [message #1856257 is a reply to message #1856256] Tue, 29 November 2022 15:19 Go to previous messageGo to next message
I also submitted a bug for this.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=581147
Re: Svn Connectors site not available [message #1856259 is a reply to message #1856256] Tue, 29 November 2022 18:03 Go to previous messageGo to next message
That worked. Thanks.
Re: Svn Connectors site not available [message #1856299 is a reply to message #1856259] Thu, 01 December 2022 12:22 Go to previous messageGo to next message
I don't know anyone at Polarion and thus cannot influence their actions.
All we have, are the sources (see developer guide) and updated artifacts which only provide the SVNKit connector (see installation instructions). The JavaHL connector was dropped in version 4.8.0 in favour of SVNKit:
https://projects.eclipse.org/projects/technology.subversive/releases/4.8.0/plan
https://bugs.eclipse.org/bugs/show_bug.cgi?id=578854
Can't you switch to the SVNKit connector?
Re: Svn Connectors site not available [message #1856301 is a reply to message #1856299] Thu, 01 December 2022 12:49 Go to previous messageGo to next message
The issue is that SVNKit seems to conflict with Tortoise a lot more and so you can't use both it and Eclipse at the same time. That works fine with JavaHL.
Also SVNKit seems to not use the user home subversion config/auth files.
Re: Svn Connectors site not available [message #1856323 is a reply to message #1856301] Fri, 02 December 2022 16:11 Go to previous messageGo to next message
I did some testing and switching SVN Connectors to SVNKit from JavaHL causes it to immediately lock all the working copy DBs regardless of if it is performing any SVN actions or not. JavaHL only grabs a lock when it is actively doing something like updating.
Re: Svn Connectors site not available [message #1857010 is a reply to message #1856323] Thu, 12 January 2023 12:24 Go to previous messageGo to next message
Nicolas, is there any plan to address those shortcomings with the SVNKit connector? We can't switch to them as they currently stand without creating workflow problems around authentication and using other SVN tools concurrently with Eclipse.
Re: Svn Connectors site not available [message #1858442 is a reply to message #1857010] Mon, 03 April 2023 06:24 Go to previous messageGo to next message
Sorry, I lost track of this discussion.
Michael Thompson wrote on Fri, 02 December 2022 22:11
I need more information on this because I cannot imagine the problem right now. Best would be a ticket on GitLab where you describe the problem a little bit more in detail: https://gitlab.eclipse.org/eclipse/subversive/subversive/-/issues
Michael Thompson wrote on Thu, 12 January 2023 18:24
I just reported an issue that I ran into: I used the svn command-line client once for updating or committing on the project and since then I'm unable to commit using Subversive: https://gitlab.eclipse.org/eclipse/subversive/subversive/-/issues/222
If it is related to the shortcomings you mentioned, feel free to add further details/outcomes. If I forgot something, let me know or file a ticket, please.
P. S. Right now, I don't know how long it will take to resolve these issues. I have several other tasks on my list which are hindering me to take care of this issue immediately.
Re: Svn Connectors site not available [message #1858994 is a reply to message #1858442] Thu, 04 May 2023 12:13 Go to previous message
No problem, thank you for your help. I've added two tickets to describe the primary issues with the SVNKit connector.
DB Locking:
https://gitlab.eclipse.org/eclipse/subversive/subversive/-/issues/228
Authentication:
https://gitlab.eclipse.org/eclipse/subversive/subversive/-/issues/227
Previous Topic:[2012-12] SVN Connector not found
Next Topic:Subversive SVN integration for the M2E project
Current Time: Tue Jul 22 00:56:59 EDT 2025
Powered by FUDForum. Page generated in 0.07191 seconds
