Error creating PDA for syntactic sequencer (2.29.0) [message #1856115] |
Tue, 22 November 2022 06:25  |
I have three grammars: Base.xtext, Base2.xtext, Mydsl.xtext
Base.xtext
grammar org.xtext.example.Base with org.eclipse.xtext.common.Terminals
generate myBase "http://www.xtext.org/example/base/MyBase"
Basic:
name=ID
KEYWORDID:
ID | "foo"
Base2.xtext
grammar org.xtext.example.Base2 with org.xtext.example.Base
generate myBase2 "http://www.xtext.org/example/base/MyBase2"
Basic2:
name=ID
KEYWORDID2:
ID | "foo"
Mydsl.xtext
grammar org.xtext.example.dsl.Mydsl with org.xtext.example.Base2
generate myDsl "http://www.xtext.org/example/dsl/MyDsl"
Model:
greetings+=Greeting*;
Greeting:
'Hello' name=KEYWORDID lastname=ID '!';
The Mydsl grammar depends on Base2 and Base: Mydsl -with-> Base2 -with-> Base.
While executing the mwe2 workflow for the Mydsl grammar, I get the following error:
1137 ERROR SyntacticSequencerPDAProvider - Error creating PDA for syntactic sequencer for contexts: Basic2 returns Basic2: no type found for name=unresolved_rule
java.lang.RuntimeException: no type found for name=unresolved_rule
at org.eclipse.xtext.serializer.analysis.SyntacticSequencerPDAProvider.getType(SyntacticSequencerPDAProvider.java:703)
at org.eclipse.xtext.serializer.analysis.SyntacticSequencerPDAProvider.createAbsorberState(SyntacticSequencerPDAProvider.java:564)
at org.eclipse.xtext.serializer.analysis.SyntacticSequencerPDAProvider.createAbsorberState(SyntacticSequencerPDAProvider.java:569)
at org.eclipse.xtext.serializer.analysis.SyntacticSequencerPDAProvider.getSyntacticSequencerPDAs(SyntacticSequencerPDAProvider.java:631)
at org.eclipse.xtext.serializer.analysis.SemanticSequencerNfaProvider.getSemanticSequencerNFAs(SemanticSequencerNfaProvider.java:240)
at org.eclipse.xtext.serializer.analysis.GrammarConstraintProvider.getConstraints(GrammarConstraintProvider.java:624)
at org.eclipse.xtext.xtext.generator.serializer.SemanticSequencerExtensions.getGrammarConstraints(SemanticSequencerExtensions.java:112)
at org.eclipse.xtext.xtext.generator.serializer.SerializerFragment2.generateAbstractSemanticSequencer(SerializerFragment2.java:417)
at org.eclipse.xtext.xtext.generator.serializer.SerializerFragment2.generate(SerializerFragment2.java:211)
at org.eclipse.xtext.xtext.generator.CompositeGeneratorFragment2.generate(CompositeGeneratorFragment2.java:43)
at org.eclipse.xtext.xtext.generator.XtextGenerator.invokeInternal(XtextGenerator.java:228)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:133)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:35)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:213)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:38)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:21)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:103)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:63)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:53)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:78)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:36)
at org.codehaus.mojo.exec.ExecJavaMojo$1.run(ExecJavaMojo.java:254)
at java.base/java.lang.Thread.run(Thread.java:829)
1142 ERROR SyntacticSequencerPDAProvider - Error creating PDA for syntactic sequencer for contexts: KEYWORDID2 returns null: no type found for unresolved_rule
java.lang.RuntimeException: no type found for unresolved_rule
at org.eclipse.xtext.serializer.analysis.SyntacticSequencerPDAProvider.createEmitterStates(SyntacticSequencerPDAProvider.java:605)
at org.eclipse.xtext.serializer.analysis.SyntacticSequencerPDAProvider.createAbsorberState(SyntacticSequencerPDAProvider.java:574)
Worked with 2.18.0.
I'd be thankful for any ideas.
Sebastian
[Updated on: Tue, 22 November 2022 06:28] by Moderator
FUDForum. Page generated in 2.01460 seconds
