Home » Modeling » EMF » Xcore validation fails in Maven Release Build
Xcore validation fails in Maven Release Build [message #1856007] Tue, 15 November 2022 05:50 Go to next message
not sure if this is an EMF/Xcore issue or a Xtend/Xtext issue, but I give it a try here:
I have a model defined in Xcore, that references an Enum that is defined in the same package.
In Eclipse the connection seems to work fine and my local Maven/Tycho-Build works fine. The regular Build also works fine on our central Jenkins CI Build.
But there is a problem when I try to build a release through maven-release-plugin.
It works, when I try the release from my local windows machine, but it fails when I try to run it in Jenkins Build.
09:51:49  [INFO] [INFO] Validate and generate.
09:51:53  [INFO] [INFO] Validating: 'TelegramModel.xcore'
09:51:53  [INFO] [ERROR] ERROR:The method or field EiSiDialogSubvariant is undefined (file:/home/jenkins/workspace/iUZ_Release_Docker/src/java/iuz/target/checkout/src/java/iuz/bundles/de.scheidtbachmann.iuz.model.zsb2000.cantelegrams/model/TelegramModel.xcore line : 2013 column : 248)
09:51:53  [INFO] [ERROR] ERROR:The method or field name is undefined for the type Object (file:/home/jenkins/workspace/iUZ_Release_Docker/src/java/iuz/target/checkout/src/java/iuz/bundles/de.scheidtbachmann.iuz.model.zsb2000.cantelegrams/model/TelegramModel.xcore line : 2013 column : 295)
I have no idea what is broken. Any help possible?
Re: Xcore validation fails in Maven Release Build [message #1856009 is a reply to message #1856007] Tue, 15 November 2022 11:35 Go to previous messageGo to next message
The EMF project does not provide any maven plugins for building Xcore. Those come from Xtext so best to ask there.
Re: Xcore validation fails in Maven Release Build [message #1856042 is a reply to message #1856009] Wed, 16 November 2022 12:16 Go to previous message
to me this looks like a java or asm version problem
can you check the plugins classpath by running build with -X
and then compare this one with the snapshot build
[Updated on: Wed, 16 November 2022 12:17] by Moderator
Previous Topic:Memory disposal during unload()
Next Topic:[CDO] net4j reconnect session timeout exception, no reconnect
Current Time: Wed Jul 30 22:16:35 EDT 2025
Powered by FUDForum. Page generated in 0.06014 seconds
