Home » Eclipse Projects » Eclipse Titan » GRE-in-UDP for MCData IP Connectivity
GRE-in-UDP for MCData IP Connectivity [message #1855745] Mon, 31 October 2022 12:39 Go to next message
Hi Titan experts,
I need to implement in our MCX test suite GRE-in-UDP for MCData IP Connectivity 3GPP TS 24.582 Rel 17 section 13 which in turn is based on RFC 8086 over DTLS. Quite a lot of encapsulation!
The application is for secure point-to-point communication for Future Railway Mobile Communication System (FRMCS).
My question is if someone has an example of DTLS usage with Titan to start with.
Thanks for any hints.
Olaf
Re: GRE-in-UDP for MCData IP Connectivity [message #1855763 is a reply to message #1855745] Wed, 02 November 2022 03:48 Go to previous messageGo to next message
The IPL4 test port supports DTLS over UDP.
Basically just connect the UDP socket, and call the StartTLS function.
For UDP server side, use the {dtls:={udp:={}}} proto instead of {udp:={}}
Re: GRE-in-UDP for MCData IP Connectivity [message #1855764 is a reply to message #1855763] Wed, 02 November 2022 03:52 Go to previous messageGo to next message
Wow, thanks, Gábor!
I will investigate.
Olaf
Re: GRE-in-UDP for MCData IP Connectivity [message #1855810 is a reply to message #1855764] Fri, 04 November 2022 04:40 Go to previous messageGo to next message
Hi Gábor,
I experimented with the IPL4 test port.
The code below attached for running client/server TLS between two machines works 50% of the executions but not 100%.
Changing the proto form {ssl:={}} to dtls:={udp:={}}} it should work for DTLS.
But it does not work :-(
Olaf
  • Attachment: TLSTest.ttcn
    (Size: 4.98KB, Downloaded 97 times)
Re: GRE-in-UDP for MCData IP Connectivity [message #1855823 is a reply to message #1855810] Sat, 05 November 2022 13:48 Go to previous message
Now DTLS transfer works 100% of the executions :-)
Thanks, Gábor for the hint to the excelent IPL4 framework
The cfg at the Client side needed:
*.dtlsPort.ssl_reconnect_attempts := "100" // ??
And the cfg at the Server side:
*.dtlsPort.pureNonBlocking := "yes" // why ??
Olaf
Previous Topic:XER: Untagged optional union decoding
Next Topic:XSD anyElement trouble
Current Time: Mon Jul 21 00:08:03 EDT 2025
Powered by FUDForum. Page generated in 0.26495 seconds
