Home » Modeling » Papyrus » Can't Use Papyrus SysML 1.4(SysML 1.4 in October 2022)
Can't Use Papyrus SysML 1.4 [message #1855710] Thu, 27 October 2022 15:57 Go to next message
Due to several reasons I need to model using Papyrus SysML 1.4, NOT SysML 1.6 (I know the latest standard is Papyrus SysML 1.6).
I am using Eclipse Installer 2022‑06 R, then installing Eclipse Modeling Tools, then Papyrus SysML 1.4 1.3.2.
Once I am done and re-start my machine, I can't find the Papyrus perspective in the Eclipse IDE.
Does anyone know if there is a way to make it appear? Or is this a legit bug?
Thanks!
Re: Can't Use Papyrus SysML 1.4 [message #1855728 is a reply to message #1855710] Fri, 28 October 2022 12:13 Go to previous message
Hi Jose,
SysML14 is not supported for the latest releases of Papyrus. EOL was 2019-06 [2] and support was switched to SysML16.
Thought you might be able to make it work on later versions I can't really tell you where this would end in random problems.
Are you set on using 2022-06R ? You can view all the released bianiries from here if you have any doubts on whether a release was meant for a version or not [1].
When you say that you are using the installer, are you referring to oomph or the market place ?
In any case I'll try to look at why this is possible and work on a fix to prevent this in the future.
HTH,
/Quentin
[1] https://download.eclipse.org/modeling/mdt/papyrus/components/sysml14/
[2] https://download.eclipse.org/modeling/mdt/papyrus/updates/releases/2019-06/
[Updated on: Fri, 28 October 2022 12:15] by Moderator
Previous Topic:Problem when installing BPMN Papyrus
Next Topic:[Code Gen] State machine guards
Current Time: Mon Jul 21 05:58:01 EDT 2025
Powered by FUDForum. Page generated in 0.23766 seconds
