Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Linking an actor to a use case
Linking an actor to a use case [message #1855690] Thu, 27 October 2022 05:31 Go to next message
Hi everyone,
I've created a use case diagram where I have one actor outside the system package. This actor should be linked to one of the use case inside the system package. I am using the "Association" for this. When I validate my model it says "The association between the actor and the use case is not directed". An assciation should not be directed I think. But even when I set one end og the association navigable, it doesn't work.
Does anybody this problem?
Thank you and best regards
Larissa
I'm using CHESS 1.0.0: Windows 64bit
Re: Linking an actor to a use case [message #1855713 is a reply to message #1855690] Fri, 28 October 2022 03:10 Go to previous message
Please use the Papyrus forum to ask questions about it:
https://www.eclipse.org/forums/index.php/f/121/
Previous Topic:[EMF Forms] EMF Combo Box in GenericEditor
Next Topic:Best tooling to replace Texo
Current Time: Mon Jul 21 01:58:13 EDT 2025
Powered by FUDForum. Page generated in 0.10449 seconds
