[CDO] ChangedInTargetAndDetachedInSourceConflict resolution [message #1855630] |
Mon, 24 October 2022 12:47  |
Consider the following use case:
- EObjects A and B exist in the CDO repository with no relation between them
- Client 1 creates EObject A1 as child of A
- Client 1 makes a reference to A1 in B
- Client 2 deletes A and commit
- Client 1 gets the conflict ChangedInTargetAndDetachedInSourceConflict for A
I try to apply a generic resolution for this conflict: delete A, all its children and the references to them.
I found a solution that works but I'm not sure if it's the proper way.
I use a MergingConflictResolver and override the resolveConflicts(Set<CDOObject> conflicts, CDOChangeSet remoteChangeSet) to do for each ChangedInTargetAndDetachedInSourceConflict:
internalCDOObject.cdoInternalSetState(CDOState.CONFLICT);
CDOStateMachine.INSTANCE.detach(internalCDOObject);
lastSavePoint.getDetachedObjects().remove(vCDOID);
A and A1 are deleted but the reference to A1 still exists in B. To remove it, I apply on the new objects removed during the conflict resolution, the the same treatment as in the beginning of the invalidate() method of CDOTransactionImpl:
removeCrossReferences(deletedNewObjects, lastSavePoint.getDirtyObjects().values());
removeCrossReferences(deletedNewObjects, lastSavePoint.getNewObjects().values());
(I had to copy the removeCrossReferences() method, could it be possible to make it not private?)
Is it the best solution to get the desired result?
FUDForum. Page generated in 0.03938 seconds
