Home » Language IDEs » C / C++ IDE (CDT) » Eclipse will not start(error loading hook: BaseHookConfigurator)
Eclipse will not start [message #1855528] Wed, 19 October 2022 11:39 Go to next message
I have MinGW and Eclipse 4.3.2 for C++ installed along with a Java jdk. Eclipse will not start. What is going wrong? Am I missing a plugin? Is config file incorrect?
First error in log is:
!MESSAGE error loading hook: org.eclipse.osgi.internal.baseadaptor.BaseHookConfigurator
!STACK 0
java.lang.reflect.InaccessibleObjectException: Unable to make protected void java.net.URLClassLoader.addURL(java.net.URL) accessible: module java.base does not "opens java.net" to unnamed module @79698539
2nd error in log is:
!MESSAGE Startup error
!STACK 1
java.lang.NullPointerException: Cannot invoke "org.eclipse.osgi.internal.baseadaptor.BaseStorage.initialize(org.eclipse.osgi.baseadaptor.BaseAdaptor)" because "this.storage" is null
The whole log file:
!SESSION 2022-10-19 10:14:19.880 -----------------------------------------------
eclipse.buildId=4.3.2.M20140221-1700
java.version=16.0.1
java.vendor=Amazon.com Inc.
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.cpp.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.cpp.product
!ENTRY org.eclipse.osgi 4 0 2022-10-19 10:14:20.067
!STACK 0
at java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(AccessibleObject.java:357)
at java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(AccessibleObject.java:297)
at java.base/java.lang.reflect.Method.checkCanSetAccessible(Method.java:199)
at java.base/java.lang.reflect.Method.setAccessible(Method.java:193)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.findMethod(BaseStorage.java:180)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.findMethod(BaseStorage.java:187)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.findAddURLMethod(BaseStorage.java:171)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.<init>(BaseStorage.java:141)
at org.eclipse.osgi.internal.baseadaptor.BaseHookConfigurator.addHooks(BaseHookConfigurator.java:24)
at org.eclipse.osgi.baseadaptor.HookRegistry.loadConfigurators(HookRegistry.java:178)
at org.eclipse.osgi.baseadaptor.HookRegistry.initialize(HookRegistry.java:100)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.<init>(BaseAdaptor.java:98)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:78)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.base/java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:499)
at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:480)
at org.eclipse.core.runtime.adaptor.EclipseStarter.createAdaptor(EclipseStarter.java:738)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:259)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:78)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:567)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
!ENTRY org.eclipse.osgi 4 0 2022-10-19 10:14:20.110
!STACK 1
at org.eclipse.osgi.baseadaptor.BaseAdaptor.initializeStorage(BaseAdaptor.java:123)
at org.eclipse.osgi.framework.internal.core.Framework.<init>(Framework.java:192)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:263)
Re: Eclipse will not start [message #1855530 is a reply to message #1855528] Wed, 19 October 2022 13:32 Go to previous message
Your IDE is from 2014 but your Java version is from 2021. You should update to the current release, 2022-09, and the LTS release of Java: 17.
Previous Topic:Breakpoint problem
Next Topic:How to run Freertos on Arduino UNO using eclipse IDE
Current Time: Sun Aug 31 18:11:46 EDT 2025
Powered by FUDForum. Page generated in 0.05350 seconds
