Home » Modeling » EMF » Generating errors in java class from an xsd file that contains special character like "µ"(my java classes doesn't understand the µ and ° character and replace them with "?".)
Generating errors in java class from an xsd file that contains special character like "µ" [message #1855434] Thu, 13 October 2022 15:20 Go to next message
Hello community,
I had an xsd file that contains an element whithim their values containes different special character like :
<xsd:enumeration value="DB/µV"/>
<xsd:enumeration value="dB(A)"/>
<xsd:enumeration value="°"/>.
When I generate the model ,my java classes doesn't understand the µ and ° character and replace them with "?".
How can I fix it?
Re: Generating errors in java class from an xsd file that contains special character like "µ&q [message #1855435 is a reply to message #1855434] Fri, 14 October 2022 02:14 Go to previous message
Those aren't valid characters to use in a *.xsd for this purpose.
Best would be to add ecore:name annotation to give it a meaningful name:
<xsd:enumeration ecore:name="Degree" value="°"/>
Of course you should declare xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" too. For me that generates this:
DEGREE(0, "Degree", "\u00b0")
Previous Topic:Proper way to store and save EObjects
Next Topic:[EMF] Dedicated editing domain for each model element editor in RCP?
Current Time: Thu Sep 18 09:03:46 EDT 2025
Powered by FUDForum. Page generated in 0.04288 seconds
