Home » Modeling » Papyrus » Linking Activity diagrams to one another(Hey, is ist possiblke to link activity diagrams to one another or create any kind of relationship?)
Linking Activity diagrams to one another [message #1855280] Thu, 06 October 2022 03:39 Go to next message
I created an Use Case Diagram with several Use Cases. Most of them are linked to one "main" Use Case via extend. In this main Use Case I created an activity diagram but I don't want to show the whole sequence. The sequences are modelled in the activity diagrams of the other Use Cases. The Activity Diagram of the main Use Case is an Overview. Can I link the Activity Diagrams of the other Use Cases to the Activity diagram of the main Use Case?
Thank you!
I'm using Eclipse Platform Version Neon.3 (4.6.3) and Papyrus UML modeller Version 2.0.3.201703080851
Re: Linking Activity diagrams to one another [message #1855285 is a reply to message #1855280] Thu, 06 October 2022 06:16 Go to previous message
Hi Larissa,
thera are mainly twp possibilities.
1. you can drag'n'drop a diagram onto another
2. you can hyperlink diagrams
/Carsten
Previous Topic:adding operations to a Class
Next Topic:Programmatically change the order of applied stereotypes
Current Time: Sat May 31 22:59:00 EDT 2025
Powered by FUDForum. Page generated in 0.03857 seconds
