Home » Eclipse Projects » EGit / JGit » 'Checkout this version' on files in a Stash issues with new or deleted files
'Checkout this version' on files in a Stash issues with new or deleted files [message #1855127] Thu, 29 September 2022 05:48 Go to next message
When I selectively try to do 'Checkout this version' on files in a Stash, if my selection of files contains a mix of new and changed files, only the changed files are checked out.
New files must be manually selected together and then 'Checkout this version' on that selection works
Doing an 'Checkout this version' on deleted files never works
Is this a bug? I see no reason why it would work the way it does and it be great if 'Checkout this version' just works on whatever selection of files you make
Re: 'Checkout this version' on files in a Stash issues with new or deleted files [message #1855132 is a reply to message #1855127] Thu, 29 September 2022 07:47 Go to previous messageGo to next message
And on a related note: When applying the entire stash, it seems any new files are always skipped, forcing you to manually select them and do 'Check out this version'
Re: 'Checkout this version' on files in a Stash issues with new or deleted files [message #1855259 is a reply to message #1855132] Wed, 05 October 2022 04:47 Go to previous message
Maybe when applying a stash any new files in the stash are only skipped if there are conflicts applying the stash
Previous Topic:Setting Default Remote Branch Destination
Next Topic:Could not connect to SSH agent via socket
Current Time: Sun Jun 08 20:53:10 EDT 2025
Powered by FUDForum. Page generated in 0.03595 seconds
