After installing eclipse-java-2022-09 I cannot create Maven project using archetype [message #1855084] |
Wed, 28 September 2022 03:21  |
After installing eclipse-java-2022-09 I cannot create Maven project using archetype (Create simple project works fine).
My environment :
Eclipse: "installed" from eclipse-java-2022-09-R-win32-x86_64.zip
Java: "installed" from openjdk-19_windows-x64_bin.zip
Note: Eclipse m2e - Maven support in Eclipse IDE - updated today 08:15 Wednesday, September 28, 2022.
System: windows 11 .
In the console I have:
Scanning for projects...
Downloading from : https://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-metadata.xml
Downloading from : https://repo.maven.apache.org/maven2/org/codehaus/mojo/maven-metadata.xml
Progress (1): 2.5/14 kB
Progress (1): 4.1/14 kB
Progress (1): 1.4/14 kB
Progress (2): 1.4/14 kB | 0.8/21 kB
Progress (2): 1.4/14 kB | 1.4/21 kB
Progress (2): 0.6/14 kB | 1.4/21 kB
Progress (2): 0.6/14 kB | 2.7/21 kB
Progress (2): 0.6/14 kB | 3.4/21 kB
Downloaded from : https://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-metadata.xml (14 kB at 24 kB/s)
Downloaded from : https://repo.maven.apache.org/maven2/org/codehaus/mojo/maven-metadata.xml (21 kB at 34 kB/s)
Downloading from : https://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-archetype-plugin/maven-metadata.xml
Progress (1): 980 B
Downloaded from : https://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-archetype-plugin/maven-metadata.xml (980 B at 8.7 kB/s)
----------------org.apache.maven:standalone-pom-------------------
Building Maven Stub Project (No POM)
--------------------------------[ pom ]---------------------------------
>>>maven-archetype-plugin:3.2.1:generate (default-cli) generate-sources standalone-pom>>>
<<<maven-archetype-plugin:3.2.1:generate (default-cli) generate-sources standalone-pom<<<
--- maven-archetype-plugin:3.2.1:generate (default-cli) standalone-pom ---
Generating project in Interactive mode
Archetype repository not defined. Using the one from [org.apache.maven.archetypes:maven-archetype-quickstart:1.4] found in catalog remote
Using property: groupId = MyEmpty
Using property: artifactId = MyEmpty
Using property: version = 0.0.1-SNAPSHOT
Using property: package = MyEmpty.MyEmpty
Confirm properties configuration:
groupId: MyEmpty
artifactId: MyEmpty
version: 0.0.1-SNAPSHOT
package: MyEmpty.MyEmpty
Y: :
And then eclipse hangs...
When I cancel the job I get:
Failed to create project.
java.lang.RuntimeException: Process exit value was 1
My error log contains:
!SESSION 2022-09-28 08:10:11.115 -----------------------------------------------
eclipse.buildId=4.25.0.I20220831-1800
java.version=17.0.4.1
java.vendor=Eclipse Adoptium
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.ui 4 0 2022-09-28 08:10:49.757
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NullPointerException: Cannot invoke "java.io.File.getParentFile()" because the return value of "org.apache.maven.model.Model.getPomFile()" is null
at org.eclipse.m2e.core.internal.project.ProjectConfigurationManager.getProjectName(ProjectConfigurationManager.java:943)
at org.eclipse.m2e.core.ui.internal.wizards.MavenProjectWizardLocationPage.validate(MavenProjectWizardLocationPage.java:299)
at org.eclipse.m2e.core.ui.internal.wizards.MavenProjectWizardLocationPage.lambda$1(MavenProjectWizardLocationPage.java:124)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:183)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4251)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1090)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1071)
at org.eclipse.swt.widgets.Combo.wmCommandChild(Combo.java:3210)
at org.eclipse.swt.widgets.Control.WM_COMMAND(Control.java:4896)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4748)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5036)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(Native Method)
at org.eclipse.swt.widgets.Combo.callWindowProc(Combo.java:474)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4846)
at org.eclipse.swt.widgets.Combo.windowProc(Combo.java:2825)
at org.eclipse.swt.widgets.Combo.callWindowProc(Combo.java:490)
at org.eclipse.swt.widgets.Combo.windowProc(Combo.java:2711)
at org.eclipse.swt.internal.win32.OS.SendMessage(Native Method)
at org.eclipse.swt.widgets.Combo.paste(Combo.java:1518)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at org.eclipse.ui.internal.handlers.WidgetMethodHandler.execute(WidgetMethodHandler.java:119)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:283)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:97)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:317)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:251)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:173)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:156)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:488)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:485)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.executeCommand(KeyBindingDispatcher.java:308)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.press(KeyBindingDispatcher.java:580)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.processKeyEvent(KeyBindingDispatcher.java:647)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:439)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:96)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1065)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1075)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1117)
at org.eclipse.swt.widgets.Combo.sendKeyEvent(Combo.java:1854)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1113)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1542)
at org.eclipse.swt.widgets.Combo.wmChar(Combo.java:3050)
at org.eclipse.swt.widgets.Combo.windowProc(Combo.java:2633)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5028)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(Native Method)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3643)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:823)
at org.eclipse.jface.window.Window.open(Window.java:799)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:263)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:283)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:389)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:142)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:580)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:414)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4068)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3645)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:643)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:550)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:171)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:402)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:596)
at org.eclipse.equinox.launcher.Main.run(Main.java:1467)
!ENTRY org.eclipse.m2e.core.ui 4 0 2022-09-28 08:12:06.338
!MESSAGE Failed to create project.
!STACK 0
java.util.concurrent.ExecutionException: java.lang.RuntimeException: Process exit value was 1
at java.base/java.util.concurrent.CompletableFuture.reportGet(CompletableFuture.java:396)
at java.base/java.util.concurrent.CompletableFuture.get(CompletableFuture.java:2073)
at org.eclipse.m2e.core.ui.internal.archetype.ArchetypeGenerator.createArchetypeProjects(ArchetypeGenerator.java:125)
at org.eclipse.m2e.core.ui.internal.wizards.MavenProjectWizard$3.doCreateMavenProjects(MavenProjectWizard.java:246)
at org.eclipse.m2e.core.ui.internal.wizards.AbstractCreateMavenProjectJob$1.doCreateMavenProjects(AbstractCreateMavenProjectJob.java:51)
at org.eclipse.m2e.core.ui.internal.wizards.AbstractCreateMavenProjectsOperation.run(AbstractCreateMavenProjectsOperation.java:57)
at org.eclipse.m2e.core.ui.internal.wizards.AbstractCreateMavenProjectJob.runInWorkspace(AbstractCreateMavenProjectJob.java:55)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:43)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Caused by: java.lang.RuntimeException: Process exit value was 1
at org.eclipse.m2e.internal.launch.EclipseMavenLauncher$1.lambda$1(EclipseMavenLauncher.java:97)
at java.base/java.util.Optional.ifPresent(Optional.java:178)
at org.eclipse.m2e.internal.launch.EclipseMavenLauncher$1.launchesTerminated(EclipseMavenLauncher.java:91)
at org.eclipse.debug.internal.core.LaunchManager$LaunchesNotifier.run(LaunchManager.java:305)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.debug.internal.core.LaunchManager$LaunchesNotifier.notify(LaunchManager.java:262)
at org.eclipse.debug.internal.core.LaunchManager.fireUpdate(LaunchManager.java:1057)
at org.eclipse.debug.core.Launch.fireTerminate(Launch.java:479)
at org.eclipse.debug.core.Launch.handleDebugEvents(Launch.java:644)
at org.eclipse.debug.core.DebugPlugin$EventNotifier.run(DebugPlugin.java:1226)
at org.eclipse.debug.core.DebugPlugin$EventNotifier.dispatch(DebugPlugin.java:1260)
at org.eclipse.debug.core.DebugPlugin$EventDispatchJob.run(DebugPlugin.java:492)
... 1 more
Please help...
Regards.
[Updated on: Thu, 29 September 2022 22:24] by Moderator
FUDForum. Page generated in 0.02930 seconds
