Home » Modeling » Ecore Tools » UML Profile to Ecore
UML Profile to Ecore [message #1854566] Thu, 25 August 2022 14:31 Go to next message
I have created an UML Profile with some stereotypes. Now I want to generate the ecore model code. Therefore I have created a genmodel file. The file was created but I get a lot of errors and the genmodel editor shows me errors, too.
It is possible to create an UML profile with a corresponding genmodel/ecore? When yes, what I'm doing wrong?
https://i.ibb.co/WyvM6Zy/uml-profile.png
Now I create the genmodel and get first errors:
https://i.ibb.co/10XFf9G/uml-profile-error-1.png
If I chose "process all" in the genmodel wizard, then I get no errors but genmodel editor gets me some.
https://i.ibb.co/MCRp5wz/uml-profile-error-2.png
[Updated on: Thu, 25 August 2022 14:37] by Moderator
Re: UML Profile to Ecore [message #1854609 is a reply to message #1854566] Mon, 29 August 2022 11:16 Go to previous messageGo to next message
To create a genmodel directly from an UML profile to generate the model code doesn't work. Select Profile element in UML Editor and open the menu entry "UML Editor -> Convert to -> Ecore Model".
Re: UML Profile to Ecore [message #1854612 is a reply to message #1854609] Tue, 30 August 2022 02:18 Go to previous message
Hi.
This forum is for questions about the Ecore Tools project (https://www.eclipse.org/ecoretools/). You should probably ask in the UML2 forum: https://www.eclipse.org/forums/index.php/f/117/
Previous Topic:Can I create DDL from an Ecore model
Next Topic:[EMF Forms] EMF Combo Box in GenericEditor
Current Time: Wed Jul 30 07:32:16 EDT 2025
Powered by FUDForum. Page generated in 0.07660 seconds
