Home » Eclipse Projects » Sirius » Extending Sirius UI (tab-bar)(Extending Sirius in a Java Plugin)
Extending Sirius UI (tab-bar) [message #1854497] Mon, 22 August 2022 13:59 Go to next message
Hi, I am trying to add a simple button in the eclipse modeling UI for my runtime eclipse application using my plugin, except the UI breaks when i do so...
I will put 2 full screen images to put in context how the tab bar is broken, sorry for the size.
Here is a view before, see the tab bar above the diagram, where the mouse is:
https://i.imgur.com/bYvHlYW.png
And here is a view after
https://i.imgur.com/5TwIysd.png
I am adding my tabbar contribution like so:
import org.eclipse.ui.menus.CommandContributionItem;
import org.eclipse.ui.menus.CommandContributionItemParameter;
import org.eclipse.ui.menus.ExtensionContributionFactory;
import org.eclipse.ui.menus.IContributionRoot;
import org.eclipse.ui.services.IServiceLocator;
public class testExtension extends ExtensionContributionFactory {
	public testExtension() {
		// TODO Auto-generated constructor stub
	public void createContributionItems(IServiceLocator serviceLocator, IContributionRoot additions) {
		String cmdId = "org.epimodel.createEpidemic";
		CommandContributionItemParameter x = new CommandContributionItemParameter(
				serviceLocator,
                cmdId,
                cmdId,
                null,
                null,
                null,
                null,
                cmdId,
                cmdId,
                cmdId,
                CommandContributionItem.STYLE_PUSH,
                cmdId,
                true);
		additions.addContributionItem(new CommandContributionItem(x), null);
I know I most likely put cmdId in too many argument places but I don't think that's the problem.
IF i do NOT call addContribuionItem(...) the UI is not broken.
Re: Extending Sirius UI (tab-bar) [message #1854501 is a reply to message #1854497] Mon, 22 August 2022 16:04 Go to previous messageGo to next message
I can see my button if I stretch the window :)
https://i.imgur.com/bqVyq0N.png
Re: Extending Sirius UI (tab-bar) [message #1854502 is a reply to message #1854501] Mon, 22 August 2022 16:09 Go to previous messageGo to next message
Now my button is gone I absolutely do not understand this tab bar :(
https://i.imgur.com/MCPW1T2.png
Re: Extending Sirius UI (tab-bar) [message #1854503 is a reply to message #1854502] Mon, 22 August 2022 16:11 Go to previous messageGo to next message
If I extend the window to click my button I get an error saying the operation is not enabled, then i can close the diagram and when I reopen it the tab bar is fine but without my button.
Re: Extending Sirius UI (tab-bar) [message #1854508 is a reply to message #1854503] Tue, 23 August 2022 01:48 Go to previous messageGo to next message
Resolved (kinda)
The tab bar is still huge BUT i can get my button on the screen even when clicking on diagram elements now, specifically the problematic property was String label being too long I assume, changed it to "label" instead of "org.epimode.createEpidemic"
				serviceLocator, // IServiceLocator serviceLocator
				cmdId, // String id
				cmdId, // String commandId
				null, // Map parameters
				null, // ImageDescriptor icon
				null, // ImageDescriptor disabledIcon
				null, // ImageDescriptor hoverIcon
				"label", // String label
				null, // String mnemonic
				null, // String tooltip
				CommandContributionItem.STYLE_PUSH, // int style
				null, // String helpContextId
				true); // boolean visibleEnabled
Re: Extending Sirius UI (tab-bar) [message #1854708 is a reply to message #1854508] Fri, 02 September 2022 18:31 Go to previous message
Hi Bruno,
If I got it correctly, you made your tabbar extension "with just Eclipse" but we also have our own abtract classes (org.eclipse.sirius.diagram.ui.tools.api.editor.tabbar.AbstractTabbarContributor) to help you and it should bypass these graphical issues. I recommand to have a look to this guide: https://www.eclipse.org/sirius/doc/developer/extensions-provide_tabbar_extensions.html
Steve
Previous Topic:[Sirius] Access to local resources of modeling project
Next Topic:Processing LinkedHashMap (Json) Object with AQL
Current Time: Wed Jul 30 08:05:54 EDT 2025
Powered by FUDForum. Page generated in 0.04755 seconds
