Home » Eclipse Projects » P2 » artifacts.xml documentation?(I need to modify the artifacts.xml, where can I find documentation on its format?)
artifacts.xml documentation? [message #959266] Fri, 26 October 2012 11:26 Go to next message
After the build of our product is done, I encrypt the class files in my JAR files of the p2 repository and I also sign them. Obviously after such modifications the information about the size and the md5 in the artifacts.xml is no longer accurate.
The format of the artifacts.xml is pretty much self explanatory but there are a few cases where I am lost.
For example sometime the artifact.size is either 0 or greater than the download.size. Why? How is the artifact.size value calculated?
Where can I find documentation on this?
Thank you all for your help!
Daniel
Re: artifacts.xml documentation? [message #959292 is a reply to message #959266] Fri, 26 October 2012 11:51 Go to previous messageGo to next message
The artifact size can be bigger than the download size if the artifact is zipped or pack'ed200. For example, the eclipse.exe is zipped and the artifact.size would be bigger than download.size.
This is usually calculated from the size of the file / files that is being put in the archive
Don't be to bothered by this attribute though since it is only used to provide estimates to the user in one of the install dialog.
HTH
Re: artifacts.xml documentation? [message #1768048 is a reply to message #959292] Thu, 13 July 2017 05:28 Go to previous messageGo to next message
Pascal Rapicault wrote on Fri, 26 October 2012 15:51
HTH
So does the property "artifact.size" is not considered in any of the operations of the eclipse tycho plugin and in p2 repo-generation?.
Re: artifacts.xml documentation? [message #1854496 is a reply to message #1768048] Mon, 22 August 2022 11:19 Go to previous message
There gotta be some sort of documentation/xsd. Why is this product documented so poorly?
Previous Topic:Install plugin no p2.director
Next Topic:Issue with p2 published
Current Time: Mon Jul 21 02:53:57 EDT 2025
Powered by FUDForum. Page generated in 0.04775 seconds
