javax support missing [message #1854355] |
Mon, 15 August 2022 15:38  |
I installed a new version of Eclipse and java on my Mac. I have created HelloWorl and other simple code, but when I try to import or use the javax.sound.midi stuff, I get "cannot resolve to a type." Annotations too, RowSet (SQL)
Eclipse is just not seeing any of the javax stuff, and I've spent hours trying to figure this out. Help!!!
Versions
MacOS: 12.5
Java: 16.0.2
sh-3.2# java -version
java version "16.0.2" 2021-07-20
Java(TM) SE Runtime Environment (build 16.0.2+7-67)
Java HotSpot(TM) 64-Bit Server VM (build 16.0.2+7-67, mixed mode, sharing)
Eclipse:
Version: 2022-06 (4.24.0)
Build id: 20220609-1112
[Updated on: Tue, 16 August 2022 16:09] by Moderator
Re: javax support missing [message #1854418 is a reply to message #1854414] |
Thu, 18 August 2022 02:06  |
No matter which forum to which you post, you'll need to share more details because if it works for everyone except you we need to understand what's different in the project where you are trying to do this. That's why Nitin asked you to share details about the project's setup. Note that you share screen captures by using Preview Quick Reply and the Upload File.
FUDForum. Page generated in 0.51333 seconds
