Home » Polarsys » CHESS » CHESS 1.0.0 installation problem(The installation of CHESS fails due to missing dependencies)
CHESS 1.0.0 installation problem [message #1830106] Fri, 17 July 2020 07:33 Go to next message
Dear all,
I am trying to install CHESS on my laptop by following the guidelines at the following link: https://www.eclipse.org/chess/start.html . Everything proceeds smoothly until I reach the installation of CHESS itself. When I add the update site and select the CHESS feature I get an error due to a missing dependency (see the screenshot attached). I guess the problem is the missing installation of Epsilon, since EOL is missing. In this respect I tried to install Epsilon from their update site but the installation fails.
For your convenience, I am running on a Mac OSX 10.15.5.
Thanks for any possible help,
Antonio
Re: CHESS 1.0.0 installation problem [message #1830119 is a reply to message #1830106] Fri, 17 July 2020 10:33 Go to previous messageGo to next message
Thanks for the reporting issue, we are working on it.
However, if you have the possibility to use Linux or Windows, you can dowload the CHESS 1.0.0 bundle directly from the download page.
Alberto
Re: CHESS 1.0.0 installation problem [message #1832473 is a reply to message #1830119] Fri, 18 September 2020 09:49 Go to previous messageGo to next message
Dear Alberto,
are there any news about the issue I faced just before the summer? I am sorry but I have only access to Mac devices.
Thanks for your help and regards,
Antonio
Re: CHESS 1.0.0 installation problem [message #1832563 is a reply to message #1832473] Mon, 21 September 2020 04:13 Go to previous messageGo to next message
I apologize for the late reply.
I plan to work to this issue this week.
Re: CHESS 1.0.0 installation problem [message #1832618 is a reply to message #1832563] Tue, 22 September 2020 03:44 Go to previous messageGo to next message
Dear Antonio,
Now the CHESS.p2f file is updated and the reference to the update-sites SDE and EST are changed.
Could you please try again the installation procedure?
Alberto
Re: CHESS 1.0.0 installation problem [message #1832619 is a reply to message #1832618] Tue, 22 September 2020 03:50 Go to previous messageGo to next message
Dear Alberto,
sure, I will retry during the day and let you know. Thanks for the feedback!
Antonio
Re: CHESS 1.0.0 installation problem [message #1832653 is a reply to message #1832618] Tue, 22 September 2020 14:53 Go to previous messageGo to next message
Hi again Alberto,
unfortunately I still have several issues when I try to install CHESS. First I have got an incompatibility problem when importing the CHESS.p2f file, where apparently 2 components already exist in the installation in a newer version (I attach a screenshot of that problem). Everything else worked flawlessly until I tried to install CHESS from the update site (please note that in the guide there are 2 different links to the site). In this case the installation fails with a problem due to missing components. Also in this case I am attaching a screenshot.
Thanks again for the support,
Antonio
Re: CHESS 1.0.0 installation problem [message #1832667 is a reply to message #1832653] Wed, 23 September 2020 03:18 Go to previous messageGo to next message
Did you start the procedure from scratch, from the eclipse-modeling-neon-3?
Compared to the previous version of the the CHESS.p2f, I've only added a missing dependency. You should have had the same problem on the first try too. Am I wrong?
Did you uncheck "Install latest version of selected software"?
You should use the new links in the guide to the update-sites. Could you please attach the the error related to the new update sites?
Re: CHESS 1.0.0 installation problem [message #1832680 is a reply to message #1832667] Wed, 23 September 2020 05:26 Go to previous messageGo to next message
Dear Alberto,
I re-did the installation from scratch again, just to be sure. For the first problem it is my fault, I did it so many times that I jumped the step of removing ECore Diagram Editor and removed only Parsley. So the only pending issue now is with CHESS plugins installation. I am attaching the description on the CHESS page (https://www.eclipse.org/chess/start.html) and I marked the 3 different links one could see for the update site. I am using the first one, and when I try to install CHESS I get the problem as shown in the other screenshot I am attaching.
Antonio
Re: CHESS 1.0.0 installation problem [message #1832687 is a reply to message #1832680] Wed, 23 September 2020 07:38 Go to previous messageGo to next message
I updated the CHESS.e2f file with the missing dependency. I tested the entire procedure and it works to me.
I think you could re-import the CHESS.e2f without starting from the beginning of the procedure. Remember to uncheck "Install latest version of selected software".
I've also updated the references to the CHESS update-sites (thanks for the tip).
Re: CHESS 1.0.0 installation problem [message #1832690 is a reply to message #1832687] Wed, 23 September 2020 07:49 Go to previous messageGo to next message
Hi Alberto,
I am glad to confirm that now the installation works properly. Thanks a lot for your patience and dedication!
Antonio
Re: CHESS 1.0.0 installation problem [message #1854114 is a reply to message #1832690] Mon, 01 August 2022 14:11 Go to previous messageGo to next message
Hi Alberto.
I'm also attempting to install CHESS on my Mac, but I'm having trouble with the EST installation dependencies.
Cannot complete the install because one or more required items could not be found.
Software being installed: Eclipse Standard Tools 1.0.0.202207110926 (eu.fbk.eclipse.standardtools.feature.feature.group 1.0.0.202207110926)
Missing requirement: KratosExecService 1.0.0.202207110926 (eu.fbk.eclipse.standardTools.KratosExecService 1.0.0.202207110926) requires 'bundle eu.fbk.tools.adapter.core 0.0.0' but it could not be found
Cannot satisfy dependency:
From: Eclipse Standard Tools 1.0.0.202207110926 (eu.fbk.eclipse.standardtools.feature.feature.group 1.0.0.202207110926)
To: eu.fbk.eclipse.standardTools.KratosExecService [1.0.0.202207110926]
I've attached the screenshot for your reference.
Any help?
Felicien
Re: CHESS 1.0.0 installation problem [message #1854124 is a reply to message #1854114] Tue, 02 August 2022 04:11 Go to previous messageGo to next message
Hi Felicien,
I've just updated the https://www.eclipse.org/chess/start.html page.
The following update-sites:
http://es-static.fbk.eu/tools/eclipse_sde/
http://es-static.fbk.eu/tools/eclipse_est/
should be replaced with:
http://es-static.fbk.eu/tools/eclipse/eata/
http://es-static.fbk.eu/tools/eclipse/sde/
http://es-static.fbk.eu/tools/eclipse/est/
Re: CHESS 1.0.0 installation problem [message #1854128 is a reply to message #1832690] Tue, 02 August 2022 11:05 Go to previous messageGo to next message
Hello Alberto,
I did follow your guidance, but on all the links provided, it appear to have no software deployed. Could you please double-check on them again?
I'm getting the errors shown in the attached image. I also tried to check with other eclipses I had, but the issue remains.
Thank you.
Kind Regards
Felicien
[Updated on: Tue, 02 August 2022 11:05] by Moderator
Re: CHESS 1.0.0 installation problem [message #1854129 is a reply to message #1854128] Tue, 02 August 2022 11:11 Go to previous messageGo to next message
My mistake. I meant:
http://es-static.fbk.eu/tools/eclipse/neon/eata/
http://es-static.fbk.eu/tools/eclipse/neon/sde/
http://es-static.fbk.eu/tools/eclipse/neon/est/
Re: CHESS 1.0.0 installation problem [message #1854147 is a reply to message #1854129] Wed, 03 August 2022 08:44 Go to previous messageGo to next message
Hello Alberto,
I successfully installed all of the components, but when I tried to install the CHESS1.1.0 update features, I encountered the issue with the FT generator plugin dependencies, as shown in the image.
Any help?
Felicien
Re: CHESS 1.0.0 installation problem [message #1854148 is a reply to message #1854147] Wed, 03 August 2022 08:54 Go to previous message
It seems you don't have the sirius.samples feature installed.
Try to install it from the following update-site:
http://www.eclipse.org/modeling/amalgam/downloads/package/modeling/neon/
You can find the feature in the category "modeling".
Previous Topic:C++ code generation with CHESS
Next Topic:CHESS Contract property must be set and syntax of formal properties
Current Time: Mon Jul 21 02:49:54 EDT 2025
Powered by FUDForum. Page generated in 0.08856 seconds
