Home » Eclipse Projects » Eclipse Titan » error: `@SBC-AP-Containers.ProtocolIE-Container' is a parameterized type assignment"
error: `@SBC-AP-Containers.ProtocolIE-Container' is a parameterized type assignment" [message #1854127] Tue, 02 August 2022 09:01
Hi, I'm currently using the ASN1 definitions of SBc-AP (3GPP TS 29.168) in ttcn3 [1],
So I end up with a template like this, which is fine:
template (value) SBC_AP_PDU
ts_SBCAP_WRITE_WARNING_RESP(template (value) BIT16 p_msg_id, template (value) BIT16 p_ser_nr,
		       template (value) SBC_AP_Cause cause := SBC_AP_Cause_message_accepted) := {
	successfulOutcome := {
		procedureCode := id_Write_Replace_Warning,
		criticality := reject,
		value_ := {
			write_Replace_Warning_Response := {
				protocolIEs := {
						id := SBC_AP_Constants.id_Message_Identifier,
						value_ := { Message_Identifier := p_msg_id }
						id := SBC_AP_Constants.id_Serial_Number,
						value_ := { Serial_Number := p_ser_nr }
						id := SBC_AP_Constants.id_Cause,
						value_ := { Cause := enum2int(valueof(cause)) }
				protocolExtensions := omit
Now, I wanted to replace each {...} IE content with a template, something like:
template (value) ProtocolIE_Container ts_Containerrr(integer bla) := {
						value_ := { Cause := bla }
But I got a compilation error:
"SBC_AP_Containers.asn:84: error: `@SBC-AP-Containers.ProtocolIE-Container' is a parameterized type assignment
Checking at ETSI ES 201 873-7 V4.8.1, that doesn't seem to be possible?
10 Parameterization in ASN.1
It is not permitted to reference parameterized ASN.1 definitions from within the TTCN-3 module. However,
non-parameterized ASN.1 definitions may reference parameterized ASN.1 definitions by providing the actual
parameters. Such ASN.1 definitions can be imported to and used in TTCN-3 and when importing all definitions of an
ASN.1 module, such definitions shall also be imported.
[1] https://gitea.osmocom.org/ttcn3/osmo-ttcn3-hacks/src/branch/master/library/sbcap
Previous Topic:the cfg of tft in 3gpp
Next Topic:Cross level indicates whether the optional field exists
Current Time: Mon Jul 21 02:21:01 EDT 2025
Powered by FUDForum. Page generated in 0.04171 seconds
