Home » Modeling » TMF (Xtext) » Fomratting won't work correctly when save xtext resource programmatically AbstractFormatter2(Fomratting won't work correctly when save xtext resource programmatically AbstractFormatter2)
Fomratting won't work correctly when save xtext resource programmatically AbstractFormatter2 [message #1854107] Mon, 01 August 2022 11:02 Go to next message
When I try to save xtext resource programmatically formatting won't work correctly? if I apply manual formatting from editor it works.
We are extending AbstractFormatter2.
Before saving i move few object in emf and save.
Do semantic model differ when we save resource programmatically?
Any input will be appreciated.
Nagaraj
Re: Fomratting won't work correctly when save xtext resource programmatically AbstractFormatter2 [message #1854109 is a reply to message #1854107] Mon, 01 August 2022 11:04 Go to previous messageGo to next message
in doubt it is a bug. can you provide a reproducing unit test?
did you compare if the textedits calculated are the same?
Re: Fomratting won't work correctly when save xtext resource programmatically AbstractFormatter2 [message #1854111 is a reply to message #1854109] Mon, 01 August 2022 11:27 Go to previous messageGo to next message
@Christian Dietrich Thank you quick reply I did some comparison i found slight difference but why its happening not sure.
Basically what i was trying to do was , move few object from one container to other container and save programmatically.
PFA of report. Left hand side is manual formatting and right hand side is save programmatically(ITextReplacers).
In our formatter if we see anything - we append few spaces.
Formatting works through editor, but not with programmatic save.
Nagaraj
[Updated on: Tue, 02 August 2022 07:00] by Moderator
Re: Fomratting won't work correctly when save xtext resource programmatically AbstractFormatter2 [message #1854113 is a reply to message #1854111] Mon, 01 August 2022 12:48 Go to previous messageGo to next message
it looks like saving formats only the changed regions and not the complete file
also check what is the diff between the FormatterRequests the formatter is called with in both cases
=> would be nice to have a reproducing unit test
[Updated on: Mon, 01 August 2022 13:03] by Moderator
Re: Fomratting won't work correctly when save xtext resource programmatically AbstractFormatter2 [message #1854123 is a reply to message #1854113] Tue, 02 August 2022 03:36 Go to previous messageGo to next message
@Christian Dietrich Thank you, will check FormatterRequest for both manual and programmatic save.
Re: Fomratting won't work correctly when save xtext resource programmatically AbstractFormatter2 [message #1854217 is a reply to message #1854123] Mon, 08 August 2022 05:31 Go to previous message
RCA was when i was saving resource I was not passing save option map with explicitly stating formatting, though the formatter get called but it was not getting formatted correctly.
val saveOption = SaveOptions.newBuilder.format.options.toOptionsMap.
Previous Topic:can we invoke IFormatter2 through context menu?
Next Topic:Xtext spelling not working on camel case words
Current Time: Fri Nov 07 06:45:30 EST 2025
Powered by FUDForum. Page generated in 0.03539 seconds
