Home » Language IDEs » C / C++ IDE (CDT) » TM Terminal is slow as molasses on mac os X
TM Terminal is slow as molasses on mac os X [message #1851911] Thu, 21 April 2022 10:43 Go to next message
I'm a long time eclipse user, both on windows and on linux.
Now I switched on a 2019 macbook pro (with macos big sur / 11.6.5).
The terminal embedded into eclipse (AFAIK TM Terminal) is incredibly slow. There is a sensible delay between each character.
I don't have any problem with the "native" terminal app (or even with other terminal applications, such as Konsole)
Is there some configuration I'm missing?
Re: TM Terminal is slow as molasses on mac os X [message #1852277 is a reply to message #1851911] Sat, 07 May 2022 14:35 Go to previous messageGo to next message
Vito De Tullio wrote on Thu, 21 April 2022 14:43
The terminal embedded into gbwhatsapp eclipse (AFAIK TM Terminal) is incredibly slow. There is a sensible delay between each character.
Hi Everyone I'm facing same issue but mine is macbook air
[Updated on: Sun, 08 May 2022 14:08] by Moderator
Re: TM Terminal is slow as molasses on mac os X [message #1854054 is a reply to message #1851911] Fri, 29 July 2022 09:51 Go to previous message
I have the same issue with a "Command Shell Console" inside the "Console" window (Eclipse 2022-06 (4.24.0) Build id: 20220609-1112, macOS 11.6.8). Input is so slow that the terminal is unusable.
Terminals in the "Terminal" window work better but are still terribly slow.
Previous Topic:CDT GCC Build Parser doesn't index the header files
Next Topic:Keeping language.settings.xml under source control?
Current Time: Thu Jul 24 20:44:44 EDT 2025
Powered by FUDForum. Page generated in 0.03825 seconds
