Home » Modeling » EMF » How can I see the exact query EMF executes?
How can I see the exact query EMF executes? [message #1853745] Sat, 16 July 2022 12:29 Go to next message
I have the following line of code:
EcoreUtil.delete( (EObject) entryToRemove, true );
It takes ~60 mins to be completed. How can I understand the reason why it takes so much time? And is it possible to see queries EMF executes? For example, in Hibernate I can print every single query. Is it possible with EMF? Or maybe someone knows another way to debug my code. I appreciate any ideas.
Thank you.
Re: How can I see the exact query EMF executes? [message #1853753 is a reply to message #1853745] Sat, 16 July 2022 15:45 Go to previous messageGo to next message
My guess is that you have a large and probably flat model. But perhaps you have a slow connection to a CDO database ...
Run under the debugger and once it has had a minute to get into the 'loop' you can just stop it and examine the stack to see what is looping and how often.
Ed Willink
Re: How can I see the exact query EMF executes? [message #1853765 is a reply to message #1853753] Sun, 17 July 2022 04:58 Go to previous messageGo to next message
Thanks! I'll try it.
Can you suggest any EMF tutorials for beginners? I switched to EMF and CDO recently and don't really understand how it works and couldn't find any good tutorials.
[Updated on: Sun, 17 July 2022 04:59] by Moderator
Re: How can I see the exact query EMF executes? [message #1853769 is a reply to message #1853753] Sun, 17 July 2022 12:19 Go to previous messageGo to next message
Hi Ed!
I tried to use my debugger and found that the for loop inside the crossReference() method (EcoreUtil class) is executing hundreds of thousands times (I used hit count in a breakpoint properties to count). What might it mean? What do you mean saying "flat model"? What might be my first step to solve this problem?
Sorry for too many question, just trying to understand how it works.
The full code of this method is below:
     * Compute the map of cross references.
    protected void crossReference()
      for (TreeIterator<Notifier> contents = newContentsIterator(); contents.hasNext();)
        Object content = contents.next();
        if (content instanceof EObject)
          EObject eObject = (EObject)content;
          if (containment(eObject))
            handleCrossReference(eObject);
          else
            contents.prune();
UPD:
I stopped with debugger inside newContentsIterator(). The code of it is:
    protected TreeIterator<Notifier> newContentsIterator()
      return new ContentTreeIterator<Notifier>(emfObjects);
I checked the size of emfObjects. The size is 1. So why is the for loop lopping and looping?
[Updated on: Sun, 17 July 2022 12:29] by Moderator
Re: How can I see the exact query EMF executes? [message #1853771 is a reply to message #1853769] Sun, 17 July 2022 16:14 Go to previous messageGo to next message
No idea. Seems like a contradiction. But the debugger will help you understand.
NB. It is very common for loops to nest, so it could well be that the particular loop you are looking at is a loop of one. It is the product of all the loop counts that is probably the problem.
Ed Willink
[Updated on: Sun, 17 July 2022 16:34] by Moderator
Re: How can I see the exact query EMF executes? [message #1853856 is a reply to message #1853771] Wed, 20 July 2022 01:53 Go to previous messageGo to next message
By default CDO loads each object only when it is needed (lazy loading). This is very good if you need to access only small parts of a very large model. But it is very slow if you need to access all objects of a very large model. And EcoreUtil.delete() needs to find all cross-referencing objects, for which it needs to access all objects.
If you want to keep using EcoreUtil.delete() you should consider prefetching all objects.
An alternative would be to use CDOView.queryXrefs() to fetch all cross-referencing objects in one server round-trip.
Re: How can I see the exact query EMF executes? [message #1853878 is a reply to message #1853856] Thu, 21 July 2022 00:54 Go to previous message
Hi Eike! Thanks for you time! Unfortunately we are still on an old version of CDO which doesn't support queryXrefs() (3.0.1).
Previous Topic:Problems using Ecore OCL for derived
Next Topic:[CDO] Offline Master/Clone example throws NPE
Current Time: Tue Sep 16 06:04:28 EDT 2025
Powered by FUDForum. Page generated in 0.04732 seconds
