[CDO]Error while prefetch lock state [message #1853140] |
Mon, 20 June 2022 03:26  |
I have some problems whit LockStateIndication.
My EMF model:
Model A , feature(EReference) ownedB , lower bound 0,upper bound 1 , containment = true.
Model B
I create a new B in Model A , than I commit.
Then I delete the B , and commit again.
LockStateIndication will have a NullPointerException.
The method prefetchLockStates(int depth, CDOID id)
Object value = revision.getValue(reference);
The value would be CDOIDNullImpl.
How to solve this problem.
Error details:
at org.eclipse.emf.cdo.server.internal.net4j.protocol.LockStateIndication.prefetchLockStates(LockStateIndic
ation.java: 97)
at og.ecliose.emf.cdo.server.internal.net4j.protocol.lockStateIndication.prefetchLockStates(LockStateIndication.java:108)at ong.eclipse.emf.cdo.server.internal.net4j.protocol.LockStateIndication.prefetchLockStates(LockStateIndic
ation.java: 120)
at ong.eclipse.emf .cdo.server .internal.net4j.protocol.LockStateIndication.prefetchLockStates(LockStateIndi
ation.java : 120)
at ong.eclipse.emf .cdo.server .internal.net4j.protocol.LockStateIndication.prefetchLockStates(LockStateIndic
ation.java: 108)
ation.java: 120)
at org.eclipse.emf .cdo.server.internal.net4j.protocol.LockStateIndication.prefetchLockStates(LockStateIndic
ation.java: 120)
ation.java: 120)
at ong.eclipse.emf .cdo.server.internal.net4j. protocol.LockStateIndication.indicating(LockStateIndication.ja
va:82)
at org.eclipse.emf . cdo.server .internal.net4j.protoco1.cOOServerIndication.indicating(CDOServerIndication .ji
va : 107)
at org.eclipse.net4j.signal.IndicationMithResponse.doExtendedInput(IndicationwithResponse.java:100)
at org.eclipse.net4j.signal.signal.doInput(Signal.java: 391)
at ong.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationMithResponse.java:73)
at org.eclipse.emf. cdo.server. internal.net4j.protocol.CDOServerReadIndication.execute(CDOServerReadIndication.java:36)... 5 more
Re: [CDO]Error while prefetch lock state [message #1853143 is a reply to message #1853140] |
Mon, 20 June 2022 04:54  |
The stacktrace you've provided is not only badly chopped, it's also fully of typos, e.g., og.ecliose, lockStateIndication, protoco1.cOOServerIndication.
And the line numbers apparently don't match the current sources.
How did you create that stacktrace and what version of CDO are you using?
Are you sure that client and server uses CDO plugins from the same release?
FUDForum. Page generated in 0.05646 seconds
