Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Is there a way to automatically display the classes children of other classes?
Is there a way to automatically display the classes children of other classes? [message #1852391] Fri, 13 May 2022 10:44 Go to next message
Lets say i have a metamodel that contains a class A : "car" and a class B : "motor" inside it.
Is is possible to make that whenever a user create a classe "car", then a class "motor" is automatically created?
Adding to that, both should be displayed.
Re: Is there a way to automatically display the classes children of other classes? [message #1852398 is a reply to message #1852391] Fri, 13 May 2022 14:19 Go to previous messageGo to next message
Your question is "context free". Of course you can create a "car" and a "motor" and if the "car" has a "motor" containment reference you can set the car's motor. But you mention a "user" doing this so I guess this is a question about an editor, I guess the generated editor.
The generated editor uses item providers to create new instances and you can specialize the methods that create such instances, e.g., have a look at org.eclipse.emf.ecore.provider.EModelElementItemProvider.collectNewChildDescriptors(Collection<Object>, Object) where we specialize the creation to create several "pre-populated" EAnnotation instances.
In general, set a breakpoint in the CarImpl constructor and you will see where/where the editor (or wizard) is creating instances and then you know where to specialize the code to also create a motor.
Re: Is there a way to automatically display the classes children of other classes? [message #1852426 is a reply to message #1852398] Mon, 16 May 2022 03:31 Go to previous message
Very interesting!
I am still a beginner in EMF, i will level up and probably come back here to reread your answer and see how I can implement his. Will write a new answer then.
Previous Topic:(To be deleted)
Next Topic:EMF diff Merge usage on this folder?
Current Time: Wed Nov 05 09:39:30 EST 2025
Powered by FUDForum. Page generated in 0.06468 seconds
