Home » Archived » Jubula » Selecting Panes(Need to select AnchorPane in Javafx)
Selecting Panes [message #1851428] Tue, 05 April 2022 10:07 Go to next message
I have a Javafx app that uses AnchorPanes to hold groups of components. I can select the panes by clicking anywhere in the pane. I can not duplicate this within Jubula. Does the Click (general components) have to be over a component or does it just send a click?
Is there a way to map Pane objects as I wish to test a property of the Pane?
Re: Selecting Panes [message #1852184 is a reply to message #1851428] Wed, 04 May 2022 03:13 Go to previous messageGo to next message
Mapping Panes is a risky thing with Jubula, in General you can achieve this, but it also has sometimes the Problem that you cannot map components which are in it.
You can try it with simple extension: https://help.eclipse.org/2020-12/topic/org.eclipse.jubula.client.ua.help/content/html/userManual/concepts/ch06s13.html
best regards
Marvin Mueller
Re: Selecting Panes [message #1852506 is a reply to message #1852184] Thu, 19 May 2022 06:50 Go to previous message
Thanks for the pointer, this did work and it did allow me to select fields enclosed in the AnchorPane. I will investigate further to see if there are any restrictions
Previous Topic:Jubula versions
Next Topic:Testing Javafx Properties
Current Time: Sun Jul 20 23:14:19 EDT 2025
Powered by FUDForum. Page generated in 0.08167 seconds
