Home » Eclipse Projects » Sirius » Obeo Designer, don't start on windows 11( )
Obeo Designer, don't start on windows 11 [message #1852055] Wed, 27 April 2022 21:34 Go to next message
I want to run the last version of Obeo Designer, on windows 11 with jvm 8 (1.8.0:331) 64 bit installed, it crash and show me errors that I copy on attached file
Could anybody tell me how can I solve it?
Re: Obeo Designer, don't start on windows 11 [message #1852056 is a reply to message #1852055] Thu, 28 April 2022 00:22 Go to previous messageGo to next message
A latest Eclipse-based product will have the at least Java 11 requirement of Eclipse.
Ed Willink
Re: Obeo Designer, don't start on windows 11 [message #1852062 is a reply to message #1852056] Thu, 28 April 2022 04:29 Go to previous message
Hi Jose,
I confirm that Obeo Designer 11.6 works on Windows 11 and java 8. Obeo Designer is based on Eclipse 2020-06 and requires at least java 8, next OD versions will require java 11.
The installation path of your java and some parameters indicate that you are using a 32 bits program. I can't guarantee that Obeo Designer will work with a 32 bits java. I suggest you to reinstall the 64 bits version of your java.
Hope it helps.
Glenn
Previous Topic:Removing default target of another diagram decoration
Next Topic:[ANN] Sirius 7.0.0
Current Time: Mon May 12 15:44:41 EDT 2025
Powered by FUDForum. Page generated in 0.03198 seconds
