Home » Newcomers » Newcomers » Eclipse 2020-12 can not create workspace in a WSL2 share
Eclipse 2020-12 can not create workspace in a WSL2 share [message #1836164] Tue, 22 December 2020 17:21 Go to next message
In Windows, WSL2 allows you to run a linux distro (in my case Ubuntu 20.04.1 LTS).
Using the share name \\WSL$\<distr- name>, you can access linux files from Windows.
I have created in WSL2 a directory with sufficient access right. With tools such as Notepad++ (or IntelliJ) (running under Windows) I can then can read and save files via the \\WSL$\<distr- name>\<dir-name> share in Linux/WSL2.
However, Eclipse (20-12) fails. I already can not create a workspace, with the error "Could not launch the product because the specified workplace cannot be created. The specified workspace directory is either invalid or read-only".
If I map the share with a drive letter (which succeeds), I also can not create a workspace (while e.g. Notepad++ can create files).
Why does Eclipse not work with WSL2 networkk shares and for example NotePad++ does?
Best,
-- Jaap
Re: Eclipse 2020-12 can not create workspace in a WSL2 share [message #1849190 is a reply to message #1836164] Thu, 06 January 2022 14:48 Go to previous messageGo to next message
Try mapping \\$wsl\<your distribution> to a network drive, for example, W: .
Re: Eclipse 2020-12 can not create workspace in a WSL2 share [message #1851959 is a reply to message #1836164] Fri, 22 April 2022 20:59 Go to previous messageGo to next message
Try add this in the end of eclipse.ini:
-Dosgi.locking=none
Re: Eclipse 2020-12 can not create workspace in a WSL2 share [message #1851960 is a reply to message #1836164] Fri, 22 April 2022 21:04 Go to previous message
The problem is that \\wsl$ directory currently dont support LockFileEx syscall. Another alternative is install you own samba server on WSL2
Previous Topic:ABAP: Not Able to Debug
Next Topic:disappearing buttons
Current Time: Mon Jul 21 00:12:52 EDT 2025
Powered by FUDForum. Page generated in 0.08862 seconds
