Home » Newcomers » Newcomers » Creating .Net Core projects(Is it better to import a repository for .Net Core)
Creating .Net Core projects [message #1851850] Tue, 19 April 2022 21:04 Go to next message
This question might require familiarity with .Net Core to answer it.
I have been doing the following to create a .Net Core project and push to a new GitHub repository.
  • Create empty repository in GitHub
  • Create a project using dotnet command in a new directory
  • Open project from file system
  • Share project (create local repository)
  • Modify files
  • Commit and push
For those unfamiliar with .Net, that works, but getting the local and remote repositories connected seems a bit cumbersome. I can do it but then I tried doing the following.
  • Import the repository into Eclipse
  • Create project using dotnet command in the project's directory
  • Refresh Eclipse of course
  • Modify files
  • Commit and push
That is easier for me. Is there a potential problem (relevant to Eclipse) I do not realize?
One thing I am not sure of is whether to import as New Project wizard or as general project. The default is general project and I assume that since it is an empty repository, New Project wizard would do nothing I need done.
For what it is worth, I am currently using How to deploy ASP.NET Blazor WebAssembly to GitHub Pages and using Eclipse for the IDE instead of Visual Studio or Visual Studio Code.
[Updated on: Tue, 19 April 2022 23:08] by Moderator
Re: Creating .Net Core projects [message #1851887 is a reply to message #1851850] Thu, 21 April 2022 03:37 Go to previous messageGo to next message
This looks generally fine. Creating/importing any type of project will create a .project file in the folder. This is an XML file that is generally hidden in the explorer views. The view menu (next to the min/max controls in the upper right of the view) has Filters... and it's possible to uncheck the .* resources filter to show them. The .project file can includes information about natures and builders, but you likely don't need any that because you don't have a Java project nor a C++ project that need such specialized configuration.
Re: Creating .Net Core projects [message #1851917 is a reply to message #1851887] Thu, 21 April 2022 12:15 Go to previous message
Thank you.
Previous Topic:Eclipse 2022 installation error
Next Topic:marketplace error after fresh install of 2020-06
Current Time: Thu Jul 24 23:06:26 EDT 2025
Powered by FUDForum. Page generated in 0.11157 seconds
