Creating a Property View Description [message #1851615] |
Mon, 11 April 2022 05:47  |
I am reading the documentation which mentions three options to create a PVD:
Quote:- The first menu is used to create a blank Properties View description. With this menu, you will start your Property View definition from scratch.
- The second menu can copy the default rules directly inside of the odesign. While powerful, those default rules can be quite complex for new users.
- The third menu can create a new Properties View which will extends the default rules. Using this mechanism, you can leverage all the default rules and you have the ability to easily add new rules.
However as you can see in the attached image, i have got only the first option, and I am using Capella Studio.
Is any reason why I would not have the 2 other options?
Thanks.
FUDForum. Page generated in 0.03275 seconds
