Home » Modeling » UML2 » [SOLVED] Profile and stereotypes are not applied in the "Intro to Profile" example
[SOLVED] Profile and stereotypes are not applied in the "Intro to Profile" example [message #1851540] Thu, 07 April 2022 18:45 Go to next message
Hi, I just launched the "Intro to Profile" example project created from the Eclipse wizard. The console seems to tell that everything was successfully generated.
But the "ExtendedPO2.uml" file doesn't show any profile and stereotype applications in the "Properties" view.
As an example, there is no "EReference" stereotype applied to the "pendingOrders" operation of the "Supplier" class although we have the following code in the project :
applyStereotype(pendingOrdersProperty, eReferenceStereotype);
What is going wrong?
Thank you.
index.php/fa/41875/0/
[Updated on: Fri, 08 April 2022 09:29] by Moderator
Re: Profile and stereotypes are not applied in the "Intro to Profile" example [message #1851543 is a reply to message #1851540] Fri, 08 April 2022 02:53 Go to previous messageGo to next message
If you look at /org.eclipse.uml2.examples.introtoprofiles/ExtendedPOEcore.metamodel.uml you should see what you expect. Perhaps you have been confused by /org.eclipse.uml2.examples.introtoprofiles/ExtendedPOEcoreBad.metamodel.uml or the unmodified original /org.eclipse.uml2.examples.introtoprofiles/ExtendedPO2.uml
Ed Willink
Re: Profile and stereotypes are not applied in the "Intro to Profile" example [message #1851545 is a reply to message #1851543] Fri, 08 April 2022 03:07 Go to previous messageGo to next message
Hi Ed,
I could not see any "ExtendedPOEcore.metamodel.uml" or "ExtendedPOEcoreBad.metamodel.uml" file in the folder of the "Intro to profile" example ("/org.eclipse.uml2.examples.introtoprofiles/").
Thank you,
Maxime
index.php/fa/41876/0/
I'm using Eclipse Modeling Tools Version: 2021-12 (4.22.0) with UML2 version 5.5.2.v20210228-1829.
Re: Profile and stereotypes are not applied in the "Intro to Profile" example [message #1851552 is a reply to message #1851545] Fri, 08 April 2022 06:11 Go to previous messageGo to next message
They are created the save calls when you successfully run /org.eclipse.uml2.examples.introtoprofiles/src/org/eclipse/uml2/examples/introtoprofiles/IntroductionToUMLProfiles.java perhaps by launching /org.eclipse.uml2.examples.introtoprofiles/IntroductionToUMLProfiles.launch
You might need to refresh the project to see them.
Ed Willink
Re: Profile and stereotypes are not applied in the "Intro to Profile" example [message #1851554 is a reply to message #1851552] Fri, 08 April 2022 06:25 Go to previous messageGo to next message
I can't see any of these files are saved in the "/org.eclipse.uml2.examples.introtoprofiles/src/org/eclipse/uml2/examples/introtoprofiles/IntroductionToUMLProfiles.java" file (see attached file).
Even after refreshing the project (using F5 or the "File > Refresh" command"), these files do not show up.
I run the project using the Eclipse "Run" button.
index.php/fa/41879/0/
Re: Profile and stereotypes are not applied in the "Intro to Profile" example [message #1851556 is a reply to message #1851554] Fri, 08 April 2022 08:19 Go to previous messageGo to next message
Confusingly / fortuitously I was using my workspace in which I had developed better functionality for [1] that includes the saves that I referred to.
If you replace /org.eclipse.uml2.examples.introtoprofiles/src/org/eclipse/uml2/examples/introtoprofiles/IntroductionToUMLProfiles.java with the attachment to the bug, you may have more success.
Ed Willink
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=569035
Re: Profile and stereotypes are not applied in the "Intro to Profile" example [message #1851563 is a reply to message #1851556] Fri, 08 April 2022 09:28 Go to previous message
Indeed, replacing the default "/org.eclipse.uml2.examples.introtoprofiles/src/org/eclipse/uml2/examples/introtoprofiles/IntroductionToUMLProfiles.java" file with the attachment to the bug solved the problem.
I'm attaching the corrected "IntroductionToUMLProfiles.java" file to this post.
Thank you Ed.
Previous Topic:UML 2.5.1
Next Topic:[SOLVED] Why a stereotype application breaks when the same profile is re-applied?
Current Time: Fri Jul 25 19:58:38 EDT 2025
Powered by FUDForum. Page generated in 0.26128 seconds
