Home » Language IDEs » Java Development Tools (JDT) » problem with Java 1.5 code
problem with Java 1.5 code [message #185118] Wed, 10 November 2004 12:27 Go to next message
Originally posted by: rkuropkat.objectsciences.com
Thought I would post here before submitting it as a bug. I am looking
at some Java 1.5 based code. The code compiles fine at the the command
line but shows errors in the IDE. eg.
code line:
seRow.setInteger(11, Integer.parseInt(Long.toString(sigact.getFred())));
error in Problems tab:
Severity Description Resource In Folder Location Creation Time
2 The method setInteger(int, Integer) in the type SeRow is not
applicable for the arguments (int, int) FredThread.java fred/src/fred
line 210 November 10, 2004 12:08:12 PM
In the compiler options I have the compiler compliance level set to 5.0.
Eclipse version 3.1.0 build id 200411050810.
Is this a bug? Configuration issue? Or feature yet to be?
Robert Kuropkat
Re: problem with Java 1.5 code [message #185126 is a reply to message #185118] Wed, 10 November 2004 13:13 Go to previous messageGo to next message
> Time
> fred/src/fred line 210 November 10, 2004 12:08:12 PM
Autoboxing is not supported yet.
You can create an Integer with the result of
Integer.parseInt(Long.toString(sigact.getFred())) and it will work.
Olivier
Re: problem with Java 1.5 code [message #185134 is a reply to message #185126] Wed, 10 November 2004 14:12 Go to previous messageGo to next message
Originally posted by: bretbb.yahoo.com
Any idea when autoboxing will be supported. It is the last milestone that
I need implemented so I can switch back to eclipse from netbeans. I had
to use NetBeans to handle enums, varargs etc..It looks like M3 handles
enums and varargs correctly now...I just need autoboxing....Can't wait
to get back to eclipse..NetBeans doesn't hold a candle to eclipse...
"Olivier Thomann" <olivier_thomannNOSPAM@ca.ibm.com> wrote in message
news:cmtlng$f05$1@eclipse.org...
> Robert Kuropkat a
Re: problem with Java 1.5 code [message #185167 is a reply to message #185134] Wed, 10 November 2004 15:49 Go to previous messageGo to next message
It is on the plan for the next milestone.
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/jdt- core-home/r3.1/main.html#milestone-plan
Olivier
Re: problem with Java 1.5 code [message #188925 is a reply to message #185167] Wed, 08 December 2004 14:28 Go to previous messageGo to next message
> Olivier
I was recently looking to develop Java1.5 with eclipse. Seeing as it's
not nearly completed, I'd like to help. I found a page at
http://www.3plus4.de/eclipse/cheetah.html detailing cvs access to the
JAVA_1.5 branch, but I've also heard that many changes found their way
back into HEAD.
So, where do I begin? What needs the most work? Any references for an
eclipse developer newbie?
~Chris
Re: problem with Java 1.5 code [message #188934 is a reply to message #188925] Wed, 08 December 2004 14:41 Go to previous messageGo to next message
> back into HEAD.
In fact everything is in HEAD now.
We need more testing of the existing support :-). You can get the latest
code from nightly builds and write 1.5 code. If you find bugs, please
report them against the JDT/Core component.
Thanks for your help,
Olivier
Re: problem with Java 1.5 code [message #188941 is a reply to message #188934] Wed, 08 December 2004 14:56 Go to previous messageGo to next message
>> it's not nearly completed, I'd like to help. I found a page at
>> back into HEAD.
> Olivier
Hmmm... I guess I'll do that. From the milestone link you posted it
says that autoboxing and static imports aren't complete. What about the
other 1.5 features? Is there a maintained list of currently supported
1.5 features?
Is there a test suite of code?
Perhaps, I'll also peruse the bug list.
~Chris
Re: problem with Java 1.5 code [message #188965 is a reply to message #188941] Wed, 08 December 2004 15:30 Go to previous message
> 1.5 features?
We don't have a complete support of autoboxing. It is partially
supported in HEAD.
Static imports don't work yet for accessing public static methods.
We know we have some issues with enum types.
You can look at the jdt.core.tests.compiler.
This is the best place to look at. All 1.5 open issues should use the
1.5 tag in the PR description.
Olivier
Previous Topic:is @SuppressWarnings supported in M3?
Next Topic:Corrupted Eclipse won't start
Current Time: Wed Sep 03 23:02:39 EDT 2025
Powered by FUDForum. Page generated in 0.42630 seconds
