Home » Modeling » TMF (Xtext) » Reference Enum Literals of an Ecore model
Reference Enum Literals of an Ecore model [message #1851248] Thu, 31 March 2022 13:30 Go to next message
I have defined a DSL, and the instances of this DSL will mostly be used to references elements of other external Ecore models.
I am encountering issues when it comes to referencing EEnumLiterals. I am including a subset of the grammar in the following:
Root:
('main' main=[ecore::EObject|QualifiedName])?
QualifiedName:
	ID ('.' ID)*
When I try to reference the EEnumLiteral that I want, in the tree editor, I get it as an alternative, but when I try to save it, it says there is an error. When I try to reference it from the textual file, I do not get it as an alternative at all.
Any idea what could be the issue, or how can it be resolved?
Thank you in advance!
John
Re: Reference Enum Literals of an Ecore model [message #1851249 is a reply to message #1851248] Thu, 31 March 2022 14:03 Go to previous messageGo to next message
how did you implement scoping? did you check if enums are indexed?
Re: Reference Enum Literals of an Ecore model [message #1851283 is a reply to message #1851249] Fri, 01 April 2022 07:48 Go to previous messageGo to next message
The enums are indexed, but I did not implement any scoping, cause I was getting everything I wanted until I came across EEnum Literals.
If I extend this a bit more to provide a better understanding, it would be the following grammar:
Load:
('load' load+=Model)
Model:
	name=STRING?
		(model=[ecore::EPackage|EString])
Root:
QualifiedName:
	ID ('.' ID)*
The possible alternatives in 'main' are EClasses,EReferences, EAttributes, and EEnumLiterals. I get the first three but not the EEnum Literals.
The qualified name should be as follows:
-For EClass : packageName.className
-For EReference: packageName.className.referenceName
-For EAttribute: packageName.className.attributeName
-For EEnumLiteral I would expect: packageName.Enum.EEnumLiteral
Does this necessarily require overriding the scope provider? If so, how could Iachieve that?
Many thanks!
Re: Reference Enum Literals of an Ecore model [message #1851291 is a reply to message #1851283] Fri, 01 April 2022 10:40 Go to previous messageGo to next message
please check EcoreQualifiedNameProvider. i assume it does not support literals.
and so they are NOT indexed.
if they are indexed. check the name they are indexed
Re: Reference Enum Literals of an Ecore model [message #1851294 is a reply to message #1851291] Fri, 01 April 2022 11:52 Go to previous messageGo to next message
Hi Christian,
sorry for bothering you with this. I checked all the files in the org.xtext.example.mydsl, both the ones generated from Xtext and the ones generated by the .genmodel. Could you please point me out on where I can find the EcoreQualifiedNameProvider. I was only able to find the online documentation and I do not see the EEnumLiterals : https://archive.eclipse.org/modeling/tmf/xtext/javadoc/2.1.0/org/eclipse/xtext/ecore/EcoreQualifiedNameProvider.html
Re: Reference Enum Literals of an Ecore model [message #1851301 is a reply to message #1851294] Fri, 01 April 2022 14:19 Go to previous messageGo to next message
its in this plugin
https://github.com/eclipse/xtext-extras/blob/92c99efc47049adddc3e3e776f774c19f3278b79/org.eclipse.xtext.ecore/META-INF/MANIFEST.MF#L4
Re: Reference Enum Literals of an Ecore model [message #1851318 is a reply to message #1851294] Sat, 02 April 2022 05:48 Go to previous messageGo to next message
This is how it looks like
 * Copyright (c) 2011 itemis AG (http://www.itemis.eu) and others.
 * This program and the accompanying materials are made available under the
 * terms of the Eclipse Public License 2.0 which is available at
 * http://www.eclipse.org/legal/epl-2.0.
 * SPDX-License-Identifier: EPL-2.0
package org.eclipse.xtext.ecore;
import java.util.Collections;
import org.eclipse.emf.ecore.EClassifier;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EOperation;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.EStructuralFeature;
import org.eclipse.xtext.naming.IQualifiedNameProvider;
import org.eclipse.xtext.naming.QualifiedName;
import org.eclipse.xtext.util.IResourceScopeCache;
import org.eclipse.xtext.util.PolymorphicDispatcher;
import org.eclipse.xtext.util.Strings;
import org.eclipse.xtext.util.Tuples;
import com.google.inject.Inject;
import com.google.inject.Provider;
 * @author Jan Koehnlein - Initial contribution and API
public class EcoreQualifiedNameProvider extends IQualifiedNameProvider.AbstractImpl {
	private PolymorphicDispatcher<String> nameDispatcher = new PolymorphicDispatcher<String>("name", 1, 1,
			Collections.singletonList(this), PolymorphicDispatcher.NullErrorHandler.<String> get()) {
		protected String handleNoSuchMethod(Object... params) {
			return null;
	@Inject
	private IResourceScopeCache cache = IResourceScopeCache.NullImpl.INSTANCE;
	public QualifiedName getFullyQualifiedName(final EObject obj) {
		return cache.get(Tuples.pair(obj, getCacheKey()), obj.eResource(), new Provider<QualifiedName>() {
			public QualifiedName get() {
				EObject temp = obj;
				String name = nameDispatcher.invoke(temp);
				if (Strings.isEmpty(name))
					return null;
				QualifiedName qualifiedName = QualifiedName.create(name);
				if(!isRecurseParent(obj))
					return qualifiedName;
				QualifiedName parentsQualifiedName = getFullyQualifiedName(obj.eContainer());
				if (parentsQualifiedName == null)
					return null;
				else
					return parentsQualifiedName.append(qualifiedName);
	protected boolean isRecurseParent(final EObject obj) {
		return obj.eContainer() != null;
	protected String getCacheKey() {
		return "fqn";
	protected String name(EPackage ePackage) {
		return ePackage.getName();
	protected String name(EClassifier eClassifier) {
		return eClassifier.getName();
	protected String name(EStructuralFeature eStructuralFeature) {
		return eStructuralFeature.getName();
	protected String name(EOperation eOperation) {
		return eOperation.getName();
Re: Reference Enum Literals of an Ecore model [message #1851319 is a reply to message #1851318] Sat, 02 April 2022 07:04 Go to previous messageGo to next message
as i said: debug this class. check out if literals are indexed.
if no it wont work without custom scoping
Re: Reference Enum Literals of an Ecore model [message #1851321 is a reply to message #1851319] Sat, 02 April 2022 11:26 Go to previous messageGo to next message
Hi Christian,
I tried what you said with the debugging. In line
If I hover over obj, then at a certain point I do get the EEnumLiteral, but it never reaches
it just skips to the other one.
Does that mean that EEnumLiterals are not indexed?
If so, is there any way I can reuse this code, to customise the scope provider to also get it for EEnumLiterals?
Many thanks!
Re: Reference Enum Literals of an Ecore model [message #1851322 is a reply to message #1851321] Sat, 02 April 2022 12:15 Go to previous messageGo to next message
Yes. I prepared a patch. You can find a preview version at
https://ci.eclipse.org/xtext/job/xtext-umbrella/job/cd_indexEEnumLiterals/lastSuccessfulBuild/artifact/build/p2-repository/
Re: Reference Enum Literals of an Ecore model [message #1851323 is a reply to message #1851322] Sat, 02 April 2022 12:17 Go to previous messageGo to next message
An no you would have to use a different syntax for Emmis literals than
QualifiedNams if you want to use custom scoping
You need two references then
One to an enumeration and a 2nd to the literal
Re: Reference Enum Literals of an Ecore model [message #1851332 is a reply to message #1851323] Sun, 03 April 2022 05:43 Go to previous messageGo to next message
Hi Christian,
Sorry I am not getting this part about the two references correctly. Is it not possible to have this qualified name in the following, only by the reference "main" in "Root":
When you say two references do you mean something like this?
[code]
main=[ecore::EObject|QualifiedName]( '.' literal=[ecore::EEnumLiteral])?
[\code]
If so, when I customise the custom provider in this case, should I do it for both references (main and literal), or only for literal and the main can have the default one that already has. Could you please provide some instructions on the steps that I have to follow to customise the scope provider ether if I need both references or only one?
Many thanks!
Re: Reference Enum Literals of an Ecore model [message #1851334 is a reply to message #1851332] Sun, 03 April 2022 06:55 Go to previous messageGo to next message
No it's not. You need a reference to something that is in the index
Like the package oder enum
As a start point
So that YOU in scope provider can as it for the literals
Your grammar is ambiguous so it won't work in all cases
So you need a different syntax
Did you test my patch ?
In scope provider you would downcast
Re: Reference Enum Literals of an Ecore model [message #1851337 is a reply to message #1851334] Sun, 03 April 2022 07:43 Go to previous messageGo to next message
I could not try the patch because I Tried Team -> ApplyPatch (tried both the url and the zip file but it says it does not contain a valid patch).
What I thought as a possible solution was the following.
In the scope provider, to first get the package (of the ecore metamodel that I am trying to reference) that contains the EEnumLiteral that I want. So reference would be MODEL__MODEL.
Then, get all the objects of this package and check if the enum chosen in "main", exists in this package. If it does,"literal" should return the values of the EEnumLiterals of that EEnum
Would this make sense?
Re: Reference Enum Literals of an Ecore model [message #1851340 is a reply to message #1851337] Sun, 03 April 2022 08:24 Go to previous messageGo to next message
No you need to instal the patch to your target platform or eclipse
And yes you need to implement scoping for that
Re: Reference Enum Literals of an Ecore model [message #1851376 is a reply to message #1851340] Mon, 04 April 2022 07:57 Go to previous messageGo to next message
HI Christian,
I implemented scoping. I have only one issue now. For the moment I return all EEnumLiterals of all Enums in the metamodel. However, I want to check the type of EEnum defined in "main", to then only return the enumliterals of that enum. However, I cannot seem to get the EEnum, I only get EObject.
For the following example:
When I do
MyDslPackage.Literals.ROOT__MAIN.getEReferenceType()
I get EObject. I understand I get EObject because even in main I say reference EObjects, but is there a name to at least get the name? For example if in the textual model in "main" have a.b, can I at least get "b"?
Or is there any way I can check if it is an ENum? because if I do, I can then in literals only return the literals of that Enum.
[Updated on: Mon, 04 April 2022 08:11] by Moderator
Re: Reference Enum Literals of an Ecore model [message #1851382 is a reply to message #1851376] Mon, 04 April 2022 10:17 Go to previous messageGo to next message
as i said
you need to cast context to
object that has
and then have something like
// you may add an instaneof hwere too
LIst<EEnumLiterals> literals = ((EEnum)object.getMain()).getLiterals()) // pseudo code
IScope scope = Scopes.scopeFor(literaks)
[Updated on: Mon, 04 April 2022 10:18] by Moderator
Re: Reference Enum Literals of an Ecore model [message #1851403 is a reply to message #1851382] Tue, 05 April 2022 02:33 Go to previous messageGo to next message
The above advice is probably good, but a note of caution. EEnumLiterals are literals, just like integers, and so depending on quite how the EEnumLiteral was created you may find that the reflective context of the EEnum is lost. In extremis, the OCL support for oclType() of an EEnumLiteral occasionally has to do a search of all metaclasses to locate all enums and thereby determine which enum the EEnumLiteral is a literal of. With hindsight, the Ecore support for EEnumLiteral could have been just a little bit richer.
Ed Willink
Re: Reference Enum Literals of an Ecore model [message #1851415 is a reply to message #1851403] Tue, 05 April 2022 06:04 Go to previous messageGo to next message
Thank you both for your answers. I was finally able to fix it based on Christian's suggestions.
Sorry if I take more of your time with some additional questions :)
1. Is using two references the only possible solution in this case? As it somehow feels more as a trick than a solution and I was wondering if it is the most appropriate one, and why there is a need to do it like this? What did you mean by not indexed and do you have any information what is the reason for that?
2. Being that the rule is like this:
(main=[ecore::EObject|QualifiedName]( '.' literal=[ecore::EEnumLiteral])?)?
QualifiedName:
	ID ('.' ID)*
I cannot actually generate Xtext Artefacts because after the dot there could either be an EEnumLiteral or another EObject. Thus, the only solution that came to my mind was to something something else instead of the dot such as:
(main=[ecore::EObject|QualifiedName]( '!' literal=[ecore::EEnumLiteral])?)?
However, is there a way, to tell xtext that if the Object in main is an EEnum then, after the dot there will be an EEnumLiteral in literal? So that I can still use the dot?
3. If I reference an object using the qualified name, lets say (a.b.c), if I just write c, then I do not get any suggestions, like I do in the tree editor. In the textual editor I have to write a.b first to then get suggestions about c. Is there anything I can do that the moment that I write c in the textual editor, I get all the qualified names leading to that?
Many thanks for all your help!
Re: Reference Enum Literals of an Ecore model [message #1851426 is a reply to message #1851415] Tue, 05 April 2022 09:52 Go to previous messageGo to next message
you can also use the patched xtext verison but you dont want to :(
you can also use a different syntax. but you dont seem to want to
[Updated on: Tue, 05 April 2022 09:54] by Moderator
Re: Reference Enum Literals of an Ecore model [message #1851429 is a reply to message #1851426] Tue, 05 April 2022 10:13 Go to previous messageGo to next message
I was having some issues trying to install the patch.
As for the second point, would you suggest a particular syntax to allow using only one reference, "main" , let's say?
Re: Reference Enum Literals of an Ecore model [message #1851434 is a reply to message #1851429] Tue, 05 April 2022 10:48 Go to previous message
Enum -> literal
Previous Topic:Xtext String no quotes
Next Topic:Xtext and Log4j/Reload4j
Current Time: Wed Nov 05 17:52:59 EST 2025
Powered by FUDForum. Page generated in 0.12648 seconds
