Home » Modeling » EMF » [CDO] How can we prevent TimeoutRuntimeException for large commits
[CDO] How can we prevent TimeoutRuntimeException for large commits [message #1851227] Thu, 31 March 2022 07:27 Go to next message
In some cases, when performing a CDOTransaction#commit with many changes, we are seeing the attached exception.
I tried to recreate the problem in a test scenario, but was not able to do so. Is this expected behavior for large commits? Which timeout would I need to increase to prevent this problem?
Re: [CDO] How can we prevent TimeoutRuntimeException for large commits [message #1851262 is a reply to message #1851227] Fri, 01 April 2022 00:07 Go to previous messageGo to next message
As CommitTransactionRequest extends CDOClientRequestWithMonitoring the regular signal timeout is periodically reset as long as the progress monitors on both client and server are advanced periodically. Only when no progress is reported for a period longer than CDONet4jSession.Options.getCommitTimeout() the CommitTransactionRequest can fail with TimeoutRuntimeException. The default value of this timeout is 10 seconds. You can change it with CDONet4jSession.Options.setCommitTimeout(int).
Unfortunately the line numbers in your stack trace don't match the latest sources, so I can't comment on the actual operations in the server that seem to take longer. But I have the feeling it might be the "synchronized (commitTransactionLock)" in Repository.commit(). That would probably mean that another commit is spending more time in commitUnsynced().
Re: [CDO] How can we prevent TimeoutRuntimeException for large commits [message #1851271 is a reply to message #1851262] Fri, 01 April 2022 04:15 Go to previous messageGo to next message
Thanks for the clarification! Increasing the timeout works for me. I was somewhat able to reproduce the exception on my test setup with the 2022-03 build.
The stacktrace is a bit different, but I attached it nevertheless. I also attached a cdo/net4j log that was printed to the console during the test.
Could it be a good idea to increase the commit timeout to a larger value by default? Maybe other users also experience the same issue...
Re: [CDO] How can we prevent TimeoutRuntimeException for large commits [message #1851275 is a reply to message #1851271] Fri, 01 April 2022 05:32 Go to previous message
Robert Schulk wrote on Fri, 01 April 2022 10:15
That would happen at the expense of waiting longer in case of "real" problems, e.g., dead locks.
I think a more appropriate solution would be to find a synchronization mechanism that is able to entertain the progress monitor while blocking...
Previous Topic:What Font Does Sample Ecore Editor Use?
Next Topic:Eclipse Indigo 3.7.2 Proxy Problem
Current Time: Sun Jul 20 20:31:01 EDT 2025
Powered by FUDForum. Page generated in 0.04006 seconds
