Error deserialising blacklisted class `javax.management.Notification` [message #1851070] |
Sat, 26 March 2022 13:03 |
We are having the following error and We didn't understand what is suggested by the message.
ERROR [scout-model-thread-12] org.eclipse.scout.rt.platform.exception.ExceptionHandler - - MDC[principal=absa, uiSession=1:dobecgvrr4kavqgl7flmp0tvsvr2bsjmmda9g1vfumbck8nm9i, scoutSession=rl4eogqc37vno85b1ba4h7h8gdj3npaehk4uuavk8naje9tfv62, jobName=Processing JSON request, cid=Nt5xD9UT5Vf/136]
org.eclipse.scout.rt.platform.exception.ProcessingException: Security check: deseserialization of class 'javax.management.Notification'. This class is blacklisted. To change the blacklist use config property 'scout.serial.blacklistAppend' or 'scout.serial.blacklistReplace' and consider class org.eclipse.scout.rt.platform.serialization.DefaultSerializerBlacklist [severity=ERROR, user=system, user=absa, calling-thread=scout-model-thread-12, job=Tunneling service request [seq=1676, submitter=Processing JSON request], ui.event=click, ui.adapter=Button[id=301, modelClass=com.groupesepro.bp.contract.client.ContractViewForm$MainBox$ValidateContractButton, parentId=277]]
at org.eclipse.scout.rt.platform.serialization.AbstractObjectSerializer$ResolvingObjectInputStream.resolveClass(AbstractObjectSerializer.java:189)
at at java.base/java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream.java:1997)
at java.base/java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java:1864)
at java.base/java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:2195)
at java.base/java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1681)
at java.base/java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java:2490)
at java.base/java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:2384)
at java.base/java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:2222)
at java.base/java.io.ObjectInputStream.readObject(ObjectInputStream.java:493)
at java.base/java.io.ObjectInputStream.readObject(ObjectInputStream.java:451)
at java.base/java.util.ArrayList.readObject(ArrayList.java:929)
at java.base/jdk.internal.reflect.GeneratedMethodAccessor112.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at java.base/java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1175)
at java.base/java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:2351)
at org.eclipse.scout.rt.platform.serialization.AbstractObjectSerializer.deserialize(AbstractObjectSerializer.java:110)
at org.eclipse.scout.rt.shared.servicetunnel.BinaryServiceTunnelContentHandler.readData(BinaryServiceTunnelContentHandler.java:101)
at org.eclipse.scout.rt.shared.servicetunnel.BinaryServiceTunnelContentHandler.readResponse(BinaryServiceTunnelContentHandler.java:59)
at org.eclipse.scout.rt.shared.servicetunnel.http.RemoteServiceInvocationCallable.call(RemoteServiceInvocationCallable.java:87)
at org.eclipse.scout.rt.shared.servicetunnel.http.RemoteServiceInvocationCallable.call(RemoteServiceInvocationCallable.java:1)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain$Chain.continueChain(CallableChain.java:227)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.runTxMandatory(TransactionProcessor.java:156)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.runTxRequired(TransactionProcessor.java:139)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.intercept(TransactionProcessor.java:78)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain$Chain.continueChain(CallableChain.java:222)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at java.base/javax.security.auth.Subject.doAs(Subject.java:423)
at org.eclipse.scout.rt.platform.security.SubjectProcessor.intercept(SubjectProcessor.java:43)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain.call(CallableChain.java:170)
at org.eclipse.scout.rt.platform.context.RunContext.call(RunContext.java:158)
at org.eclipse.scout.rt.platform.context.RunContextRunner.intercept(RunContextRunner.java:38)
at org.eclipse.scout.rt.platform.job.internal.CallableChainExceptionHandler.intercept(CallableChainExceptionHandler.java:33)
at org.eclipse.scout.rt.platform.job.internal.JobFutureTask.lambda$0(JobFutureTask.java:106)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at org.eclipse.scout.rt.platform.job.internal.JobFutureTask.run(JobFutureTask.java:175)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:829)
at org.eclipse.scout.rt.platform.job.internal.NamedThreadFactory$1.run(NamedThreadFactory.java:63)
Note that we didn't encounter this error in development nor in test doing the same action.
So I'am wondering what can be wrong with my configration in production which is exactly the same as in test.
Does anyone has an idea about ?
[Updated on: Sat, 26 March 2022 13:06] by Moderator
FUDForum. Page generated in 0.02932 seconds
