Upgrade Eclipse from 2021-12 (4.22) to 2022-03 (4.23) failed [message #1850890] |
Mon, 21 March 2022 07:47  |
After checking for updates in Eclipse 2021-12 the new version 2022-03 was offered for installation, so I gave it a try.
However, after the upgrade finished without any errors, the new version doesn't start.
The log file /my-eclipse-folder/jee-2021-06/eclipse/configuration/1647524672922.log shows that some required jars are missing, for example:
/my-eclipse-folder/jee-2021-06/eclipse/configuration/org.eclipse.osgi/358/data/431355561/plugins/org.eclipse.equinox.common_3.16.0.v20220211-2322.jar
/my-eclipse-folder/jee-2021-06/eclipse/configuration/org.eclipse.osgi/358/data/431355561/plugins/org.eclipse.osgi_3.17.200.v20220215-2237.jar
/my-eclipse-folder/jee-2021-06/eclipse/configuration/org.eclipse.osgi/358/data/431355561/plugins/org.eclipse.osgi.compatibility.state_1.2.600.v20220207-1403.jar
/my-eclipse-folder/jee-2021-06/eclipse/configuration/org.eclipse.osgi/358/data/431355561/plugins/org.eclipse.e4.tools.emf.ui_4.7.200.v20220114-0046.jar
/my-eclipse-folder/jee-2021-06/eclipse/configuration/org.eclipse.osgi/358/data/431355561/plugins/org.eclipse.e4.ui.workbench.swt_0.16.400.v20220222-1128.jar
...and many more.
I can confirm that these files are nowhere on my hard disk.
What might have gone wrong?
I use Ubuntu 20.04.4 LTS and Adoptium JDK 11.
All previous platform upgrades since 2020-03 succeeded without a problem, if you don't count that stale folders like jee-2020-03 remain and that 2021-12 was installed in jee-2021-06.
I had backed up the eclipse folder before trying the upgrade, so I managed to revert to 2021-12.
Now 2022-03 is marked as installed somewhere, so it isn't offered for installation any more.
What can I do to retry the upgrade and how can I avoid the errors?
I don't want to do a fresh installation because I don't want to reinstall all my plugins and redo all my configurations.
Re: Upgrade Eclipse from 2021-12 (4.22) to 2022-03 (4.23) failed [message #1851107 is a reply to message #1851104] |
Mon, 28 March 2022 04:51  |
I guess the certificate error is not related.
What we would be looking for is why the new bundles are not downloaded, or not moved to the correct location. The insertion of the relative path seems related. For now we are completely in the dark of what happened and without a reproduction scenario nothing can be fixed. Please add any additional information to the Bug report.
FUDForum. Page generated in 0.03944 seconds
