Home » Modeling » EMF » How to create UMLPackage object using ResourceSet?Or how to convert EPackage object to UMLPackage?(EMF )
How to create UMLPackage object using ResourceSet?Or how to convert EPackage object to UMLPackage? [message #1850925] Tue, 22 March 2022 09:08 Go to next message
I want to create a UMLPackage object using ResourceSet so that I can parse the UML model. However, I can only get the object of EPackage.
code show as below:
URI uri = URI.createURI("src/model/test.uml");
ResourceSet set = new ResourceSetImpl();
set.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
set.getResourceFactoryRegistry().getExtensionToFactoryMap()
.put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap()
Resource res = set.getResource(uri, true);
EObject root=res.getContents().get(0);
UMLPackage umlPackage=null;
for(EObject e:root.eContents()){
if("Interaction".equals(e.eClass().getName())){
umlPackage=(UMLPackage) e.eClass().getEPackage();
if(null!=umlPackage){
System.out.println(umlPackage.getLifeline());
Re: How to create UMLPackage object using ResourceSet?Or how to convert EPackage object to UMLPackag [message #1850930 is a reply to message #1850925] Tue, 22 March 2022 11:00 Go to previous message
Better to ask on the UMLforum:
https://www.eclipse.org/forums/index.php?t=thread&frm_id=117
And you should use the debugger because I assume that root is some type of UML2 instance while your "umlPackage" is the metadata (Ecore model) of the UML instance/model.
Previous Topic:Binary compatibility of EMF models
Next Topic:xtend src-gen folder relative to dsl file
Current Time: Thu Jul 31 12:56:17 EDT 2025
Powered by FUDForum. Page generated in 0.06859 seconds
